COM86 Posted July 11, 2019 Posted July 11, 2019 That attaches to the rear axle differential cover that has brake lines going to it?
Minuit Posted July 11, 2019 Posted July 11, 2019 Load sensing proportioning valve. It alters the brake bias depending on the height of the rear. When properly working, it gives you more rear braking when heavily loaded and acts as a primitive form of anti-lock.
COM86 Posted July 11, 2019 Author Posted July 11, 2019 Picture work best. Also I have noticed that a brake line comes in. Ts off goes to this and then goes somewhere else.
COM86 Posted July 11, 2019 Author Posted July 11, 2019 So would it be in the best interest for me to use it or get rid of it? 8.8 axle swap.
Dzimm Posted July 11, 2019 Posted July 11, 2019 Up to you. Some remove it, some leave it. I removed it when I redid all the brakes on both my trucks. Had them both loaded and they stopped just fine without it. Granted I don't take the highway when heavily loaded. There are many threads here on how to properly remove it. If you haul a lot, I'd probably leave it and make sure it's actually working. If you leave it, you need the bracket on the diff cover to attach it to. I've probably got an extra one I can send you if you don't have it. There are also threads on how to properly set it up.
COM86 Posted July 11, 2019 Author Posted July 11, 2019 29 minutes ago, Dzimm said: There are also threads on how to properly set it up. How would I find the thread about it?
13 Legion Posted July 11, 2019 Posted July 11, 2019 Go to DIY write ups and master search list... search under brakes. https://comancheclub.com/forum/10-mj-tech-diy-projects-and-write-ups/
fiatslug87 Posted July 11, 2019 Posted July 11, 2019 Don had written a DIY for an adjustable version.
