engine swap
I'm thinking about taking the 5.2 out of my zj and putting it into my mj, I was told (by someone who did this) that the ax15 will bolt onto this engine, any ideas on axles ext would be helpful. still not positive I'm going to do this but I need to figure something out quick, my 4.0 is going to die soon
25 minutes ago, omega_rugal said:
nope
 From what I've read, The Dakota's with the 3.9 Magnum V6 came with the AX15 and all of the Magnum engines had the same bellhousing bolt pattern. So if you use that bellhousing you can bolt your AX15 up to a 5.2 or 5.9 Magnum.
i think the dakota V6 used the NV1500, the 2.5 used the ax15
  • 1 month later...
