Instrament Cluster Problems
Ground to the cluster is attached to the dash frame just above the hood release handle.
Clean that ground.......improve that ground and every other ground on your truck.
Do you have tilt wheel? if so is it loose? just curious.
1 hour ago, Phillip Gwin said:
voltage and oil pressure also.
Then as said, clean the ground up first and/or do Cruiser's improvement.
You may also want to pull the cluster and check the plug, circuit board, etc, as I've seen them get quite corroded or gross.  The whole cluster comes apart fairly easily.  Make sure the plug is seated correctly when it goes back together.
If you have the cluster out of the vehicle, you can run test leads from the sensors directly to the posts on the various gauges to test them. There are contacts in the one of the diagnostic port blocks for the tachometer. All the other gauges, I believe, have the same ohm range -- 0 to 88 ohms,  -- so you could use a test lead setup from either the temp sender or the oil pressure sender to check them all. (Except volts -- but that's easy to test with a direct connection to the battery.)
1 hour ago, Jeep Driver said:
Actually, the entire panel does not look good.
At the very leas you are going to have to get a test light and start tracking down circuits.
I agree -- that doesn't look very good.
More important, the fuse panel is two parts. One part is on the engine side of the firewall, the part in your photo is the other side. To really investigate the condition, you need to remove the screw that holds the two halves together, separate them, and inspect those contacts.
Okay, I ran a jumper from the fusebox to the hot wire on the dash. It worked. I checked the fuse, it was good, that was in the evening. I went out today in the daylight, and the connector behind the fuse, the metal part was gone, it had copper color on one side, plastic on the other. I have jumpered around it. Will fix it right when I have more time to fool with it.
