Ls2xjcomanche Posted May 7, 2019 Share Posted May 7, 2019 Just picked up a couple female end seat belts for bucket seats. Does anyone know what this electrical wiring is for? Link to comment Share on other sites More sharing options...
Ωhm Posted May 7, 2019 Share Posted May 7, 2019 Driver's side Seatbelt Switch. Goes to the Chime Module (CM). CM will turn Safety Belt Lamp ON (Instrument Cluster), when belt is not connected. Link to comment Share on other sites More sharing options...
Ls2xjcomanche Posted May 7, 2019 Author Share Posted May 7, 2019 Cool. My comanche doesn’t have the wiring to connect it to so just going to leave it. Thanks! 15 minutes ago, Ωhm said: Driver's side Seatbelt Switch. Goes to the Chime Module (CM). CM will turn Safety Belt Lamp ON (Instrument Cluster), when belt is not connected. Link to comment Share on other sites More sharing options...
1989commanche Posted May 8, 2019 Share Posted May 8, 2019 It goes to the annoying latch your seat belt buzzer. And the little red light. That accompanies it. Link to comment Share on other sites More sharing options...
cruiser54 Posted May 8, 2019 Share Posted May 8, 2019 ejection seat. Link to comment Share on other sites More sharing options...
gogmorgo Posted May 8, 2019 Share Posted May 8, 2019 The wiring should be there somewhere, as it's required safety equipment to have the light/buzzer. If the carpet's ever been out, though, the wires are likey buried pretty deep. They could even have just retreated if they were left unplugged for a while. If it ever comes up again, as is likely, the passenger side female end is the same as the driver's side, less the electrical portion. If you're junkyard shopping XJs, they're more likely to be in good shape than the driver's side, as they get less use. You can leave the wires unplugged, and the light just won't come on. Link to comment Share on other sites More sharing options...
