Ba/10 5speed Peugot SQUARE Socket [Transmission]
If I remember right I just put a 3/8 extension in mine to drain
I tried the 3/8 but its a little too big n 1/4 is too small. What i had read was that it could work if you grind a 3/8 extension down but i’d rather have the right tool
I think I used a swivelly 3/8 extension. They are a little smaller so they can wobble.
5 hours ago, 75sv1 said:
There is the drain plug in the 4.0L block. I think 8mm square. Really tough to get out. Some are afraid to remove them as the block may crack.
that´s why i don´t remove the one in mine, after 30 years it´s probably welded shut... imagine all the trouble just for removing this plug if the block cracks...
I just used a spare chinexican 3/8" extension, and used a grinding wheel to re ove enough material from 2 sides of the extension to fit.
Hopefully I will have my 4 wd swap done soon and no more french pos trans. Although, I can't complain too much considering it has outlasted the Turdy5
