Parts are parts question
I have a WJ  I bought for parts its a 1999. I already found out I can't really use the trans as I planned.Even if I could get in working in my 1988 MJ it probably wouldn't last long.So I have other question.Can I use the axles in my 1988 MJ or my 87 XJ would this be worth the trouble.I would really like to have rear disk brakes,and the newer axles. Mine arn't getting any younger. I have seen a lot of brake upgrades were they use the disks off a WJ. Thanks for any help here. I know the 4.0 can be done I just have to use a lot of the renix parts off my old motor. There is a really great write up in here about that swap.I also saw one on using the XJ axles in an MJ,but nothing about the WJ. Is there a problem with these axle's are they weak?Can't hold up with big tires,and lifts? I'd love some feed back on the topic.Thanks
I don't know what the 6-cylinder WJ used for a rear axle. If it's the aluminum "Dana 44," it's not even a good boat anchor.
There's a thread here not more than a week or two ago about the WJ front axle. Bottom line -- it won't fit without a lot of work, and even then the wheel lug bolt circle is wrong.
OK checked the build plate at the door.It read 4/98 so is it a WJ or a ZJ title said 99.I'm guessing that makes it a ZJ.So my question would be are any of these parts usable? I have a good motor,trans,and both rearends.
That's the funny thing Pete it looks exactly like my 97 grand that's why I bought it for parts. Tail lights,bumpers down to the same rim's. Only difference is one is the V8,and the other is the 4.0. I'll get this right sooner or later ZJ  Pete its a ZJ.
I'm thinking it's a ZJ,and not a WJ.I even checked the motor mounts,and the look like my XJ only smaller.They were also in the same location.You can't really see the bolt pattern very well.So not for sure on that one.What about the axles anyone know if its worth a swap,or just use the rear disk brakes? The conversion didn't look that hard,but some newer axle's would be nice.
"newer"  :D
you'll be trading in 30 year old parts for 20 year old parts + a ton of work.  :dunno:
BUT if you get a bump in gear ratio, then it might be worth it. :L:
ZJ front axle should go right in (but is low pinion).
Yeah your right,but the 20 year old parts have a ton less miles on them 30, verses over a 100, I'm not feeling the,( low pinion) though.Maybe better to just use the disk brakes less work. I think the trans is a no go too.What you think about the 4.0 usable or not ?
All 4.0 blocks having the same engine mount.points. Completely interchangeable. They didn't cast different blocks for different applications. A bit like the LS blocks.
Edit. To clarify - However the 2001-2006 TJ blocks and 1999 to 2004 WJ blocks did have blocked off mounting points that would need to be tapped along with a water pump hole. There are some other differences that make a swap difficult but not impossible. All the ZJ and XJ blocks were all interchangeable..
Sent from my SM-G955U using Tapatalk
Well, the WJ was a completely different vehicle, so if it looks like a '97 ZJ, then it's a ZJ. Post a photo so we can see it.
The ZJ was more or less a derivative/evolution of the XJ. In fact, I've read that the ZJ was originally intended as the replacement for the XJ, but the XJ was selling so well that Jeep decided to keep it and introduce the ZJ as a separate vehicle. The WJ was to be the replacement for the ZJ, but Chrysler-Jeep went out of their way to make it completely different. I think I remember the early WJ ads making a point of how few parts on the WJ were carried over from the ZJ.
From the build date, it sounds like what you have is a '98 ZJ, not a '99 WJ. What's the VIN? That should tell us the actual year and model. If it's a ZJ, the 4.0L should go into an MJ but the electronics, fuel injection, and accessory mounting points will be different.
The fact that the ZJ front axle is a low pinion is really only a factor if you plan on serious off-road use. (Jeep changed to a low-pinion front axle in the XJ in 2000.) For the rear axle, I know the V8 ZJs used the crappy aluminum "Dana 44." I don't know what rear axle the 6-cylinder ZJs had -- if you post a good photo of the rear axle, we can probably tell you what it is.
4.0 ZJ’s will have a LP30 and a disc brake D35 in the rear. Even the early V8 ZJ’s had the 35. The front brakes will be identical to any 90-98 XJ.
Engine is the same as 96-98 XJ’s and TJ’s
TJ’s were made from 1/96-6/98 with XJ compatible engines except for the accessory mounts.
Transmission is trash.
4/98 is early enough in '98 it's unlikely to be a '99 model year, even on a new generation. It could easily be an error on the title, although I'm surprised that it could slip in like that. Digit 10 of the VIN is the model year regardless of make or model, and almost any system should be able to pick that up. '98 is W, '99 is X.
On intitial rollout every ZJ had a Turdy5, including the V8s. It was a couple years in before they offered the 44A. I think there were a couple packages where the 44A was also offered with a 4.0, but the base axle was the d35.
Thanks you guys for all the help. I've been trying to download pictures off my phone to my PC for a couple of days.I think I may be using the wrong cord.Going to try again in the morning.Its been a while since I was under that ZJ ,but if I remember the dif cover looks just like my XJ.My MJ has a different cover same shape rubber plug.I learned a long time ago in auto body school that the titles are not always 100 %. correct on the year it was made.Some states go by the year it was sold.I learned it again the hard way.John my body shop teacher would be ROFLHAO at me right now. Always check the door plate,or the tail lights unless they've been replaced they almost never lie. That sucks for me the drivers door on my MJ has been replaced.So i don't really have any build specks for my truck.The guy I bought the truck from said it was really rare 4WD,5sp,with the 4.0.That there was only 500 built like it that year.Sounds like BS to sell the truck now.I already knew that the MJ's were rare anyway,and I really liked the trucks potential.I'll get some pictures up of the truck as soon as I can. WOOHO Axles I can use,and motor check.Trans some junk to sell. Thats a great end for a bad day. Thanks again to all of you.
After yesterday I dug a couple out to check them out.This is the one off my truck 1JFT66L7KL574339.The 99 in Question 1J4Z58S6WC370994 so that W actually makes it a 98 no question there.Is there anything you can tell me about the truck?
Year/Model: 1998 JEEP GRAND CHEROKEE SPORT UTILITY 4-D Last Odometer: 1,537 miles on September 3, 1998 Body Style: ZJJL74 In-Service Date: July 27, 1998 Engine: ERH-4.0L I6 Power Tech Engine In-Service Odometer: 0 miles Transmission: DGK-4-Spd. Automatic 42RE Transmission Odometer Type: miles Color 1: PG8-Forest Green Pearl Coat Car Line: Z Color 2: QG8-Forest Green Pearl Coat Build Date: May 20, 1998 Current Market Register: U Hour: 21
Incomplete Recall Recall Number Description Part Number Launch Date B02 FLOOR SHIFTER SECONDARY DETENT SYSTEM CCXRB020 September 19, 2002 N45 TRAILER HITCH (ZJ) CBXTN451AA,CBXTN452AA,CBXTN454AA August 6, 2013
Vehicle Sale Information Selling Dealer: 23203 - HARRISBURG CHRY-JEEP Sales Type: L - BROKER City: HARRISBURG State/Province: PA Country: USA Telephone: (717)545-4726
Standard Equipment
Code Description Code Description Code Description
APAS Monotone Paint BAUS 117 Amp Alternator BCES 600 Amp Maintenance Free Battery
BRGS Anti-Lock 4-Wheel-Disc Brakes CACS Low Back Bucket Seats CFNS Rear 60/40 Folding Seat
CGWS Driver Front Passengern Air Bags CKDS Floor Carpet CKNS Cargo Compartment Carpet
CKRS Cargo Net CKTS Cargo Tie Down Loops CLES Front Rear Floor Mats
CSAS Spare Tire Cover CSCS Cargo Compartment Cover CSRS Passenger Assist Handles
CUFS Full Length Floor Console DGKS 4-Spd. Automatic 42RE Transmission DHAS Lock-Up Torque Converter
DJJS Dana 30/186MM Front Axle DMDS 3.55 Rear Axle Ratio GBBS Tinted Windshield Glass
GCBS Front Door Tinted Glass GEPS Flipper Liftgate Glass GFAS Rear Window Defroster
GNAS Rear View Day/Night Mirror GNCS Sun Visors w/Illum Vanity Mirrors GTNS Power Mirrors, Fold-Away
GXMS Keyless Entry with Panic Alarm HGAS Hood Insulation HGDS Deluxe Insulation Group
JAYS DO NOT USE - See JP, KA classes JCBS 120 MPH Primary Speedometer JHAS Var Intermittent Windshield Wipers
JHBS Rear Window Wiper/Washer JJAS Cigar Lighter JJBS Dual Note Electric Horns
JKAS Locking Glove Box JPAS Power Windows JPBS Power Locks
KRSS RADIANT SILVER MET. C/C - DIMENSION KTSS RADIANT SILVER MET. C/C - Badge KWSS RADIANT SILVER MET. C/C - Badge
K4AS NEUTRAL DARK GRAY - CLADDING LACS Illuminated Entry LAGS Warning Chime
LBBS Courtesy Lamps LBCS Glove Box Lamp LBDS Ash Tray Lamp
LDAS Underhood Lamp LDBS Cargo Compartment Lamp LMBS Halogen Headlamps
LPSS CHMSL Lamp MHAS Black Windshield Moldings MWGS Roof Rack
NF5S 23 Gallon Fuel Tank NHMS Speed Control QG8S Forest Green Pearl Coat
RASS AM/FM Cassette Radio RCDS 4 Speakers RDDS Fixed Long Mast Antenna
SBAS Power Rack and Pinion Steering SCVS Leather Wrapped Steering Wheel SDAS Normal Duty Suspension
SUAS Tilt Steering Column TBGS Compact Spare Tire TBLS Inside Mounted Spare Tire
TZAS Goodyear Brand Tires WJ6S 15X7.0 Sport Aluminum Wheels YAAS Build To U.S. Mkt. Specifications
1AAS U.S. Dealer Retail 133S Zone 33-Philadelphia 639S Pennsylvania Ship to State Code
939S Pennsylvania Sold to State Code
Optional Equipment
*F5 Cloth High Back Bucket Seats -AZ Agate ARNP Laredo Decor Group (97-02-26)
A24P 4.0L Engine(ERH)/4Spd Auto Trans(DGK CUNP Overhead Console DGB All 4-Speed Automatic Transmissions
DHPP Selec-Trac Full Time 4WD System DRJP 175MM Rear Axle EAAC All Engines
ERH 4.0L I6 Power Tech Engine GEGP Deep Tint Sunscreen Glass GRNP Left Power Fold-Away Mirror
GSNP Right Power Fold-Away Mirror GVBC All Vehicles W/Power Mirrors HAAP Air Conditioning
KGCP TC: HA8 HA2 - BODYSIDE ACCENT STR K5AP ARGENT - BODYSIDE MOLDING LETP Traveler/Mini Trip Computer
LNJ Front Fog Lamps LSA Security Alarm MDA Front License Plate Bracket
MFZP Bright Grille NAA Federal Emissions PG8 Forest Green Pearl Coat
RAAC All Radio Equipped Vehicles TRTP P225/75R15 OWL All Season Tires WLZC All Aluminum Wheels
YGCA 7 Additional Gallons of Gas ZFLP Spring - Left Front ZJSP Spring - Left Rear
ZULP Spring - Right Front ZXSP Spring - Right Rear Z6AP GVW/Payload Rating
0KYA FAM: ZJ TRACKING: 70717J09 2TXA Customer Preferred Package 2TX 26X Customer Preferred Package 26X
3CVA Regional 4X4 Discount 3VXA Customer Preferred Discount
Wow just from one number Wagon that's some cool stuff. Its now black,and not the green,and rolled a little the only straight panel left is the rear hatch.What the heck dose 175 mm rear axle mean? I see it has a dana 30 front,and 3.55 gears.I found the codes for the trans,and t case.as expected junk for what I wanted to do with it.I'm thinking someone swaped the the T case shifter plate.After being under it yesterday I don;t think its been swapped out.No marred bolts,no gouges in the under coating.I'm thinking its the stock T case.Thanks for the help Wagon.
I did some more research on the 175mm. It may be that the build code has been recycled for something else. The service info doesnt show a 175mm axle option, that and the Dana 30 is 186mm, so that code probably applies to something else now, and not the ZJ any longer. A lot of the MJ codes have been recycled the same way if you get a look at a build sheet.
here's your Comanche...
Vehicle Service Information Year/Model: 1989 JEEP COMANCHE ELIMINATOR Last Odometer: 0 miles on Body Style: MJTS61 In-Service Date: Engine: EAF-1.4L I4 16V MultiAir Turbo Engine In-Service Odometer: 0 miles Transmission: DDQ-5-Speed Manual Transmission Odometer Type: miles Color 1: PE4-Punk'n Metallic Clear Coat Car Line: XX Color 2: QE4-Punk'n Metallic Clear Coat Build Date: April 11, 1989 Current Market Register: Hour: 09
Incomplete Recall Recall Number Description Part Number Launch Date 561 OXYGEN SENSOR SEE RECALL November 8, 1993
Vehicle Sale Information Selling Dealer: 23984 - COURTESY CHRY-JEEP OF CASSELBE Sales Type: 1 - DIRECT RETAIL City: CASSELBERRY State/Province: FL Country: USA Telephone: (407)831-2828
Standard Equipment
APAS Monotone Paint BGAS Power Front Disc/Rear Drum Brakes BJAS DESCRIPTION NOT AVAILABLE
BKPS 10x2.5 Rear Drum Brakes CKAS Carpets - Floor and Cargo Area CSRS Passenger Assist Handles
DMMS 3.07 Rear Axle Ratio DRJS 175MM Rear Axle GACS Tinted Glass Windows
GBBS Tinted Windshield Glass GCBS Front Door Tinted Glass GEHS Fixed Door Vent Glass
GNAS Rear View Day/Night Mirror JAAS Instrument Panel JAYS DO NOT USE - See JP, KA classes
JBDS Instrument Panel Satin Silver Bezel JCAS 85 MPH Primary Speedometer JJAS Cigar Lighter
JKBS MOPAR Hood Lock KLHS DESCRIPTION NOT AVAILABLE K2BS STRIPE/BADGE/MOLDING/COLOR
K3RS STRIPE/BADGE/MOLDING/COLOR LAFS Seat Belt Alert-Driver Seat only LAPS Shift Indicator Warning Lamp
LBCS Glove Box Lamp LCJS Overhead Ambient Surround Lighting LMAS Halogen Headlamps
LNJS Front Fog Lamps MBJS Black Powder Coated Front Bumper MB1S Black Front Bumper
MCAS Rear Body Color Applique MFKS Body Color Grille MHAS Black Windshield Moldings
MMCS Rear Door Solid Window Insert MMGS Belt Moldings MMKS Lower Grille Surround-Painted Silver
NAAS Federal Emissions NBAS Underground Calibration NBKS EVAP Control System
NDAS Catalytic Converter NF2S 18.5 Gallon Fuel Tank QE4S Punk'n Metallic Clear Coat
SBAS Power Rack and Pinion Steering SCGS Leather Wrapped Steering Wheel SFAS Standard Duty Front Shock Absorbers
SGAS Standard Duty Rear Shock Absorbers TADS Run Flat Tires TBCS Compact Spare Tire
TBMS Tire Carrier Winch WJHS 15X7 Aluminum Wheels XBSS Pickup Box
XFAS -35F Protection Anti-Freeze YAAS Build To U.S. Mkt. Specifications Z1AS GVW/Payload Rating
1AAS U.S. Dealer Retail 166S Zone 66-Orlando
Optional Equipment
*Q7 Cloth Low-Back Bucket Seats -SA Charcoal ADAA Light Group
ALR GTS Interior Package BA1P DESCRIPTION NOT AVAILABLE BCYP 95 Amp Battery
CACP Low Back Bucket Seats CDBP Reclining Front Seats CUFA Full Length Floor Console
DBBC All Manual Transmissions DDQ 5-Speed Manual Transmission EAAC All Engines
EAFC 1.4L I4 16V MultiAir Turbo Engine ERB 3.6L V6 24V VVT Engine GFDA Rear Sliding Window
GNBP Driver Side Illuminated Sun Visor GRZP Left Remote Mirror GSZP Right Remote Control Mirror
GTZA Manual Remote Mirrors HAA Air Conditioning JGBP Digital Clock
JHAA Var Intermittent Windshield Wipers LAJP Headlamps On Warning Chimes LBBP Courtesy Lamps
LBDP Ash Tray Lamp LBEP Door Armrest Storage Lamp LDHP U/Hood, Removable/Rechargeable Lamp
LHDP Headlamp Off Time Delay LPEP Cargo Lamp PE4 Punk'n Metallic Clear Coat
RAAC All Radio Equipped Vehicles RAFA AM/FM Cassette Radio RCDP 4 Speakers
SUAA Tilt Steering Column TAAC All Tires TRMA P225/75R16 BSW On/Off Road Tires
YGEA 5 Additional Gallons of Gas Z01P Rear Spring Group I Z59P Left Front Spring Group Ix
Z78P Right Front Spring Group VIII 5ASA Dodge City Tracking 5KRA Midland Corporation
As you can see, not everything is correct anymore.
That"s good news then.Some parts I could use,and some I can sell.Any one need a trans or T case for there 4.0 ZJ. I'll move a couple of Jeeps around on monday.I'm thinking its about time to part out some of whats left of this thing.Thanks again for the help.I'm never going to get used to seeing MM on American cars.
