1 hour ago, Pete M said:
is it in a vehicle that you'd be buying/storing whole?  or an engine block that will then be sitting on the floor in a corner of a shed for a couple years?
The engine is in a shed. Just the engine.
  • Replies 593
Last Friday (April 19th) I bought a 4:10 D35 with an LSD, a D30 with gears to match, factory power mirrors, side marker lights, a 5in lift, and sway bar disconnects from a family friend who was parting out an 1986 XJ Chief. I will be keeping everything except the rear axle. The lift is for a Cherokee, but I will combine the two in order to get the lift I want. PM me for details about the rear end if you are interested.
  • 5 weeks later...
7 hours ago, Pete M said:
I'm curious to see how the drums turned out after sandblasting
The drums are not getting sandblasted. I just bought that axle for the leaf springs. However, I have had drums sandblasted in the bast and it works fine.
Build info from factory. Huge thanks to JMO413!!
*B1TRIM STYLE B1 - CLOTH && VNL BENCH SEAT
-Q8
166Zone 66-Orlando
1AAU.S. Dealer Retail
5ALLow Series Tracking
APAMonotone Paint
BAQ61 AMP ALTERNATOR
BCXNickel Metal Hydride Battery
BGAPower Front Disc/Rear Drum Brakes
BJASTD DUTY FRT DISC BRAKES
BKP10x2.5 Rear Drum Brakes
CBAStraight Back Bench Seat
CKJBlack Vinyl Floor Covering
CSRPassenger Assist Handles
CUMMini Floor Console
DBBAll Manual Transmissions
DDX5-Speed HD Manual Transmission
DHNCommand-Trac Part Time 4WD System
DJH230MM Front Axle
DMM3.07 Rear Axle Ratio
DRJ175MM Rear Axle
EAAAll Engines
EAFALL FUEL INJECTED ENGINES-GAS
ERBENGINE - 4.0L I6 MPI GAS
GACTinted Glass Windows
GBBTinted Windshield Glass
GCBFront Door Tinted Glass
GEHFixed Door Vent Glass
GNARear View Day/Night Mirror
GRZLeft Remote Mirror
GSZRight Remote Control Mirror
GTZManual Remote Mirrors
HCDDo Not Use - See HCA
JAAInstrument Panel
JAZDO NOT USE - See JP, KA classes
JBFInstrument Panel Black Bezel
JCA85 MPH Primary Speedometer
JKBMOPAR Hood Lock
K3ZSTRIPE/BADGE/MOLDING/COLOR
KDASTRIPE/BADGE/MOLDING/COLOR
LAFSeat Belt Alert-Driver Seat only
LAPShift Indicator Warning Lamp
LBCGlove Box Lamp
LCJDOME/READING LAMP B-PILLAR
LMAHalogen Headlamps
MB1Black Front Bumper
MBJBlack Powder Coated Front Bumper
MDAFront License Plate Bracket
MFFBlack Grille
MHBBright Windshield Moldings
MMCRear Door Solid Window Insert
MMGBelt Moldings
MMJDRIP TROUGH MLDG - TYPE I
NAAFederal Emissions
NBALIGHT DUTY CYCLE
NBKEVAP Control System
NDACatalytic Converter
NF218.5 Gallon Fuel Tank
PWBPEARL WHITE PRIMARY PAINT - HWB
QWBPEARL WHITE SECONDARY PAINT - HWB
RAAAll Radio Equipped Vehicles
RACAM MTR Radio
RCA19 SPKRS SRT High Perf Audio
SBAPower Rack and Pinion Steering
SCBPerforated Steering Whl w/Red Stitch
SFAStandard Duty Shock Absorbers
SGARear Shock Absorbers
TAAAll Tires
TADHIGHWAY TREAD
TBCCompact Spare Tire
TBMTire Carrier Winch
TNCP195/65R15 BSW AS Touring Tires
WJK15X6.0 Styled Steel Wheels
WMCBright Wheel Trim Rings
XBSPickup Box
XFA-35F Protection Anti-Freeze
YAABuild To U.S. Mkt. Specifications
YGB1 Additional Gallons of Gas
YGG9 Additional Gallons of Gas
Z01Rear Spring Group I
Z5AGVW/Payload Rating
Z65Left Front Group XIV
Z84Right Front Spring Group XIII
Body Model JL61
Build Date 1/3/89
Just pulled it back inside to work on it again since schools is out and the ground is dry. I started pulling the bench to check the floors. I can see a couple of rust sports form the underside though. Hopefully it is not very rusty.
Sorry no pics, but I’m sure many of you have done this before too, so you know what it looks like. I’ll get pics once I get the carpet pulled.
Pulled up the carpet. Not bad for a Wisconsin truck. I will start patching the floors soon.
Passenger side
Driver side
I also ordered a weld-yourself front bumper for $165 on Amazon. I’ll let you all know what I think of it when I get it built.
I took the grille off and turned it the correct way only to take it back off to take the grille and header panel off to get the front fender off so I can repair the floor and rocker and prep for paint.
Edited by 89 MJ
Adding pics
I got the rocker, cab corner, and floors cut out, sandblasted, and primed and ready for reinstallation. The floors will get POR 15 on them. Some pics are of the front end torn off, others are of the rocker/cab corner removal and of the floors.
11 hours ago, Pete M said:
what's the plan for the cab corners?
I am just bending up a piece that will fit, then welding it in place. I have a sheet metal brake at my disposal, so I can make precise bends.
  • 89 MJ changed the title to 89 Sportruck
