89 MJ Posted April 1, 2019 Author Share Posted April 1, 2019 On 4/1/2019 at 2:39 PM, Pete M said: is it in a vehicle that you'd be buying/storing whole? or an engine block that will then be sitting on the floor in a corner of a shed for a couple years? Expand The engine is in a shed. Just the engine. Link to comment Share on other sites More sharing options...
89 MJ Posted April 14, 2019 Author Share Posted April 14, 2019 Will be going to the Jefferson Swap Meet in Jefferson WI on the 26th. Will be looking for MJ parts. Link to comment Share on other sites More sharing options...
89 MJ Posted April 23, 2019 Author Share Posted April 23, 2019 Last Friday (April 19th) I bought a 4:10 D35 with an LSD, a D30 with gears to match, factory power mirrors, side marker lights, a 5in lift, and sway bar disconnects from a family friend who was parting out an 1986 XJ Chief. I will be keeping everything except the rear axle. The lift is for a Cherokee, but I will combine the two in order to get the lift I want. PM me for details about the rear end if you are interested. Link to comment Share on other sites More sharing options...
89 MJ Posted April 27, 2019 Author Share Posted April 27, 2019 Got a pic of my new parts. They are kinda crusty, but they will get sand blasted and painted. Link to comment Share on other sites More sharing options...
89 MJ Posted May 26, 2019 Author Share Posted May 26, 2019 Last night I took the steering stuff off of my new axles along with the rear leaf springs. It all will be getting sandblasted soon! Link to comment Share on other sites More sharing options...
Pete M Posted May 27, 2019 Share Posted May 27, 2019 I'm curious to see how the drums turned out after sandblasting Link to comment Share on other sites More sharing options...
89 MJ Posted May 27, 2019 Author Share Posted May 27, 2019 On 5/27/2019 at 4:03 AM, Pete M said: I'm curious to see how the drums turned out after sandblasting Expand The drums are not getting sandblasted. I just bought that axle for the leaf springs. However, I have had drums sandblasted in the bast and it works fine. Link to comment Share on other sites More sharing options...
89 MJ Posted June 1, 2019 Author Share Posted June 1, 2019 Build info from factory. Huge thanks to JMO413!! *B1TRIM STYLE B1 - CLOTH && VNL BENCH SEAT -Q8 166Zone 66-Orlando 1AAU.S. Dealer Retail 5ALLow Series Tracking APAMonotone Paint BAQ61 AMP ALTERNATOR BCXNickel Metal Hydride Battery BGAPower Front Disc/Rear Drum Brakes BJASTD DUTY FRT DISC BRAKES BKP10x2.5 Rear Drum Brakes CBAStraight Back Bench Seat CKJBlack Vinyl Floor Covering CSRPassenger Assist Handles CUMMini Floor Console DBBAll Manual Transmissions DDX5-Speed HD Manual Transmission DHNCommand-Trac Part Time 4WD System DJH230MM Front Axle DMM3.07 Rear Axle Ratio DRJ175MM Rear Axle EAAAll Engines EAFALL FUEL INJECTED ENGINES-GAS ERBENGINE - 4.0L I6 MPI GAS GACTinted Glass Windows GBBTinted Windshield Glass GCBFront Door Tinted Glass GEHFixed Door Vent Glass GNARear View Day/Night Mirror GRZLeft Remote Mirror GSZRight Remote Control Mirror GTZManual Remote Mirrors HCDDo Not Use - See HCA JAAInstrument Panel JAZDO NOT USE - See JP, KA classes JBFInstrument Panel Black Bezel JCA85 MPH Primary Speedometer JKBMOPAR Hood Lock K3ZSTRIPE/BADGE/MOLDING/COLOR KDASTRIPE/BADGE/MOLDING/COLOR LAFSeat Belt Alert-Driver Seat only LAPShift Indicator Warning Lamp LBCGlove Box Lamp LCJDOME/READING LAMP B-PILLAR LMAHalogen Headlamps MB1Black Front Bumper MBJBlack Powder Coated Front Bumper MDAFront License Plate Bracket MFFBlack Grille MHBBright Windshield Moldings MMCRear Door Solid Window Insert MMGBelt Moldings MMJDRIP TROUGH MLDG - TYPE I NAAFederal Emissions NBALIGHT DUTY CYCLE NBKEVAP Control System NDACatalytic Converter NF218.5 Gallon Fuel Tank PWBPEARL WHITE PRIMARY PAINT - HWB QWBPEARL WHITE SECONDARY PAINT - HWB RAAAll Radio Equipped Vehicles RACAM MTR Radio RCA19 SPKRS SRT High Perf Audio SBAPower Rack and Pinion Steering SCBPerforated Steering Whl w/Red Stitch SFAStandard Duty Shock Absorbers SGARear Shock Absorbers TAAAll Tires TADHIGHWAY TREAD TBCCompact Spare Tire TBMTire Carrier Winch TNCP195/65R15 BSW AS Touring Tires WJK15X6.0 Styled Steel Wheels WMCBright Wheel Trim Rings XBSPickup Box XFA-35F Protection Anti-Freeze YAABuild To U.S. Mkt. Specifications YGB1 Additional Gallons of Gas YGG9 Additional Gallons of Gas Z01Rear Spring Group I Z5AGVW/Payload Rating Z65Left Front Group XIV Z84Right Front Spring Group XIII Body Model JL61 Build Date 1/3/89 Link to comment Share on other sites More sharing options...
JMO413 Posted June 1, 2019 Share Posted June 1, 2019 Welcome. Link to comment Share on other sites More sharing options...
Pete M Posted June 1, 2019 Share Posted June 1, 2019 take that list with a grain of salt. Chrysler reused codes over the years. I seriously doubt your truck had a nickle metal hydride battery or a hood lock. Link to comment Share on other sites More sharing options...
JMO413 Posted June 1, 2019 Share Posted June 1, 2019 Agree with Pete Link to comment Share on other sites More sharing options...
89 MJ Posted June 4, 2019 Author Share Posted June 4, 2019 Just picked up a rust free tailgate for $100. I live in the rust belt so this is kind of a big deal for me. Link to comment Share on other sites More sharing options...
Pete M Posted June 4, 2019 Share Posted June 4, 2019 score!!! Link to comment Share on other sites More sharing options...
89 MJ Posted June 15, 2019 Author Share Posted June 15, 2019 Just pulled it back inside to work on it again since schools is out and the ground is dry. I started pulling the bench to check the floors. I can see a couple of rust sports form the underside though. Hopefully it is not very rusty. Sorry no pics, but I’m sure many of you have done this before too, so you know what it looks like. I’ll get pics once I get the carpet pulled. Link to comment Share on other sites More sharing options...
89 MJ Posted June 16, 2019 Author Share Posted June 16, 2019 (edited) Pulled up the carpet. Not bad for a Wisconsin truck. I will start patching the floors soon. Passenger side Driver side I also ordered a weld-yourself front bumper for $165 on Amazon. I’ll let you all know what I think of it when I get it built. I took the grille off and turned it the correct way only to take it back off to take the grille and header panel off to get the front fender off so I can repair the floor and rocker and prep for paint. Edited June 16, 2019 by 89 MJ Adding pics Link to comment Share on other sites More sharing options...
89 MJ Posted June 19, 2019 Author Share Posted June 19, 2019 I got the rocker, cab corner, and floors cut out, sandblasted, and primed and ready for reinstallation. The floors will get POR 15 on them. Some pics are of the front end torn off, others are of the rocker/cab corner removal and of the floors. Link to comment Share on other sites More sharing options...
89 MJ Posted June 20, 2019 Author Share Posted June 20, 2019 Got the new floors pans and rocker welded in on the driver side. Now I need to fix the passenger side floor. Link to comment Share on other sites More sharing options...
Pete M Posted June 23, 2019 Share Posted June 23, 2019 looking good what's the plan for the cab corners? Link to comment Share on other sites More sharing options...
89 MJ Posted June 23, 2019 Author Share Posted June 23, 2019 On 6/23/2019 at 2:51 AM, Pete M said: what's the plan for the cab corners? Expand I am just bending up a piece that will fit, then welding it in place. I have a sheet metal brake at my disposal, so I can make precise bends. Link to comment Share on other sites More sharing options...
89 MJ Posted July 2, 2019 Author Share Posted July 2, 2019 Just put in some Dynamat sound deadener to make it more pleasant to drive when it is done. Link to comment Share on other sites More sharing options...
89 MJ Posted July 3, 2019 Author Share Posted July 3, 2019 Pics of the Dynamat installed. On the trans tunnel, both floors, and back of the cab. Also ordered a new vinyl floor covering. Link to comment Share on other sites More sharing options...
89 MJ Posted July 12, 2019 Author Share Posted July 12, 2019 Over the past few days I got a lot done. 8.8 is in (and out again for sandblasting). Got a nicer hood. Did some rust repair and bodywork. Link to comment Share on other sites More sharing options...
89 MJ Posted July 13, 2019 Author Share Posted July 13, 2019 Did some bodywork today. Link to comment Share on other sites More sharing options...
89 MJ Posted July 17, 2019 Author Share Posted July 17, 2019 Finished bodywork on the cab and fenders and got them primed. Looking to paint it on Thursday or Friday. Link to comment Share on other sites More sharing options...
89 MJ Posted July 18, 2019 Author Share Posted July 18, 2019 Got sealer on doors and fenders today. Painting them tomorrow. Link to comment Share on other sites More sharing options...
