tprman Posted March 13, 2019 Share Posted March 13, 2019 Got a problem with my 88 MJ 4.0. It idles rough with with smoke coming out the exhaust pipe. Smells like gas But give it gas it runs good only runs rough while idling . I have checked all the vacuum lines. Did a complete tuneup. Clean the injectors. Replace the idler control, map sensor. Took the Val cover off and check to see if the Val’s are sticking they are working good. Any deals what could be wrong. What I need to check next... Link to comment Share on other sites More sharing options...
Ωhm Posted March 13, 2019 Share Posted March 13, 2019 Could be leaky injector(s). Check fuel pressure. Gauge should hold pressure after cycling KEY ON, then KEY OFF. Link to comment Share on other sites More sharing options...
carolinajeepman Posted March 13, 2019 Share Posted March 13, 2019 Did you check the EGR valve and solenoid? From the symptoms you described, it sounds like it could be your problem. Link to comment Share on other sites More sharing options...
tprman Posted March 13, 2019 Author Share Posted March 13, 2019 I did have a leaky fuel enjector. I replace the seals, but it still idling rough. I’ll check the EGR next. Thanks for the replies. Link to comment Share on other sites More sharing options...
cruiser54 Posted March 13, 2019 Share Posted March 13, 2019 Link to comment Share on other sites More sharing options...
tprman Posted March 13, 2019 Author Share Posted March 13, 2019 I check that holes. It’s good. Just wondering does it go in the top hole are the bottom hole on the back of the Throttle Body. Link to comment Share on other sites More sharing options...
All around mj Posted March 13, 2019 Share Posted March 13, 2019 If all else fails, has your throttle body been cleaned recently and if so, was the idle air control port cleaned. I can’t really remember how the throttle body is setup on the remix. Link to comment Share on other sites More sharing options...
JMO413 Posted March 13, 2019 Share Posted March 13, 2019 The MAP hose goes in the bottom. The top is blocked off. Link to comment Share on other sites More sharing options...
tprman Posted March 14, 2019 Author Share Posted March 14, 2019 Let me check my Map hole. I’ll let y’all know. Thanks. Link to comment Share on other sites More sharing options...
tprman Posted March 16, 2019 Author Share Posted March 16, 2019 I think I found my problem. Throttle body map sensor hose was bad. Thanks everyone for the help. Link to comment Share on other sites More sharing options...
JMO413 Posted March 16, 2019 Share Posted March 16, 2019 Good to hear you found it. Link to comment Share on other sites More sharing options...
tprman Posted March 16, 2019 Author Share Posted March 16, 2019 Me to. It was driving me crazy. Thank you Link to comment Share on other sites More sharing options...
