Hi folks! New to the forum and hope to find answers to an issue I can't seem to figure out myself. My friend of 25 years has an 86 comanche that he loves and intends to keep for the rest of his life ( which may not be to long due to cancer returning). The issue is finding a new double v belt harmonic balancer for his 86 2.5 mj. All I can locate are the serpentine style that obviously won't work. I am hoping that someone here has the answer to this problem, I've seen reference to the 4.2 crank pully being the same as the 2.5 with the serpentine belt but have only seen the single v belt type online for the 4.2.
I also ran across a dorman part that says it will fit the 2.5 (according to seller) but it is listed for chevy motors only elsewhere!   ANY HELP would be appreciated!
I can't say for sure, but the chevy idea definitely has merit.  for better or for worse AMC used a ton of parts from other manufacturers.
Thanks pete! According to my research so far AMC did use the GM (PONTIAC) 2.5 motor for a few years (early 80's)before creating there own 2.5 motor for the 1984/85 models.
The amc motor is an I 6 minus 2 cylinders so the 4.2 balancer may fit the 2.5 , but I don't know for certain, and don't want to get any parts without knowing for sure!
If it helps......non ac YJ'S used the double v-belt......with the 2.5
I am no expert but even though the front of the 2.5 and 4.0 are somewhat interchangeable (same water pump.....same t-stat housing ect)
The balancer would be (IMHO) different... as it would obviously need to be balanced for cylinders 5&6?
Internally balanced and harmonics should be the same.
Thanks to all who have responded so quickly, I have used jeep drivers recommendation and will see if that pans out.
In my search I contacted quadratek and was told that the serpentine belt style are the same part number for the 4 and 6 cylinder motors, but no double v style are listed.
I did find a place in California that will rebuild the balancer but can't have the mj out of service more than a day, it's his only transportation .
That looks right, I'll take it! I will revisit my searches again for more info on your serpentine set up but qtek said 4.0 and 2.5 are the same balancer.
I did find crown # 3242886 is listed for both 2.5 and 4.2 motors 1981 to 1993, it has the shoulder on the back like yours appears to in the photos.
I did run across mention that the alignment is off by 3/8 inch when using 4.0 pulleys , it could have to do with the shoulder being on the front or back of the pulley.
How confusing it all is! Perhaps this info will be of use to others when all is said and done.
I also found a dorman part (double v) that looks correct but it's listed for chevy , guess it will take finding all of the measurements ( id, od, offset, etc) to see if it will work on the 2.5 jeep motor.
Thanks for the part numbers!, those help to eliminate the 4.0 from the equation although some other parts appear to interchange,  Does the manual list the 4.2 balancer as being the same part number as the 2.5?  I am curious about that since I've found at least two retail sources that claim they are.
What I'm having a hard time with is finding a double v belt style, the serpentine style is all that I have been seeing in my search.
It may take some time to get all of the info sorted out but in the end may prove valuable to others that are trying to preserve an older jeep, and maybe save a little frustration for them as well! At this point I am going to get the one from saveevryjp1998 and keep looking for a new replacement part, worst case is that I can have the bad one rebuilt and not have to have the mj out of service for a week or more.
I will update as I find things out.
Thanks jeep driver, that is the pulley that I found that was listed for chevys, I'm going to order one from the locale parts store and compare it to the one I remove from the mj.if it's not the same it can be sent back at no cost.
I called dorman and they claimed it won't fit but I'm sorta skeptical about customer service types and I saw a listing for jcwhitney that listed it as fitting the 2.5 jeep motor- it's worth checking out.
Keep in mind that AMC/Jeep/Eagle for a time used the Pontiac Iron Duke 2.5L 4-banger in the Eagle. That has caused a LOT of people to believe absolutely that all Jeep 2.5L engines are the Iron Duke.
I was looking in the 1987-1990 parts catalog. Interestingly, there's a different part number for the 2.5L damper in the Wrangler YJ. That part number is J324 2885 ... the damper for the 2.5L in the XJ/MJ is J324 2886.
The damper for the 4.0L is 3300 2920. The damper for the 4.2L is J323 7196 with the V-belt pulley, and J323 7723 with the serpentine belt.
3 hours ago, saveevryjp1998 said:
Now you see the frustration for 2.5 guys. The best part is the 86 2.5 is a whole separate breed over the 87-90 2.5. Accessory setups with pulleys etc., the 86 2.5 is like the land of the lost for web info. I'm sure it's out there just not under mj listings:D. This is even more cause for me to like it from the small challenges to face.
From the 1986 Jeep parts catalog:
There are two dampers listed. J324 2885 is the damper for 1983-1986 without serpentine belt. J324 2857 is for 1983 with serpentine belt. J324 2886 is for 1984-1986 with serpentine belt.
For the GM 4-cylinder (used 1981-1983): J813 2264
So ... nowhere does the Jeep 2.5L damper cross with either the GM 4-cylinder engine or the Jeep 4.2L engine.
It wouldn't, why would you expect it to?
XJ/MJ never used the GM 4cyl.
XJ/MJ did use the GM V6 which the Dorman pulley I linked to does cross to.
Since the V6 and early 2.5 used GM alts and PS pumps.........I suspect they used the same balancers.
90% chance that balancer will fit.
OP, just be aware that the 2.5 came with two water pumps, the most common for the serpentine was CCW, yours will be the least common so make certain  you get the right one.
So I looked in StarParts and the J3242885 shows to go from 84 to 93 in the YJ. If you look up a Dorman balancer for a YJ it shows 2. With or without serp belt. DOR594-137 is w/o. Hope this helps.
Can you just post a link?
It may fit, physically, but it almost certainly won't balance. The GM 2.8L V6 version that GM sold to AMC/Jeep was externally balanced. There's no way an externally balanced V6 would use the same damper as an in-line 4 cylinder.
You guys are AWSOME!, it would have taken me weeks to compile this amount of information, I'm not so great with computer use-still hunt and peck with the keyboard.
The 80's have always proven to be a challenge with auto manufacturers for me, mixed sae and metric fasteners, random  part changes at any point during production, even different part numbers depending on trim color! (A late 80's maxima) I still love to repair, restore and to improve these machines!
The Crown automotive #3242886 is a serpentine style crank pulley listed as both 2.5 and 4.2 motors,81 to 93 which led me to think the balancer is interchangeable, but if the factory part numbers are different how can that be? It may just be the diameter is different which could lead to overdrive/underdrive options for the accessories? I just don't know.
Thanks for the mention of the water pump, in my studies I did find that the v belt type spins in the opposite direction of the serpentine type. I wonder how many people have had cooling issues because of this.
Thanks again to all who have chimed in on this subject! I would still be running in circles if not for you!
Assuming it did fit.............
Hop on down to the machine shop and have the HB neutrally balanced.
You welcome. I find this stuff fun. I have been a parts guy for 20 years. I believe the Dorman 594-137 should be correct.
