Tranny swap
First post thanks for the add btw! Lol
Well I have a 90 mj 4.0 renix still auto 2wd. I want to make 4wd and I have a 92 yj 4.0 h.o auto 4x4 in my driveway I have been thinking of swaping the tranny and tcase over. Would this work or no? I don't really want to do the h.o swap as the mj is my daily and not really looking to make a huge project out of the gate but would like 4x4 back. Would these be interchangeable and only thing I would have to get is shafts? Or is wiring completely different?
Your YJ if its an automatic is probably a 32RH. No electronics, a 3speed, and all hydraulic. The YJ transfer case is probably a NP231J.
The MJ automatics are AW4's, also there is a difference between the 2wd auto and the 4wd auto, transfer case could also be a NP242 in the MJ. The AW4's also have a seperate computer? (sort of computer) that works in conjunction with the Renix computer and the TPS for the automatic. Easiest swap is an MJ 4wd automatic, or a Cherokee 4wd automatic, still have to do an axle swap and a bunch of other things to have a 4wd auto MJ
Yeah there’s a computer for the transmission all the AW4 year, well not sure about 97 up.
It’s a basic computer to control the sifting. You can run without it if you want and disconnecting it is a way to test the transmission, so it’s not something that bricks the transmission.
The computer itself is a small box usually located under the dash kick panel, whatever the correct term, the panel the ashtray is in, on the passenger side.
If you’ve seen a 80-90s Toyota transmission computer it basically looks the same
Sent from my iPhone using Tapatalk Pro
Yes the yj is a 3 speed auto. I would be able to take anything from it as it is a full running vehicle. I know I would have to get an axle but want to start with getting a transmission and tcase In first and just run without from shafts as funds are limited. These Winters are brutal with a rwd vehicle esp when it's the first year I'm without it lol.
1 hour ago, Pete M said:
snow tires are better than 4wd for snow.  :L:
Hi Pete,
I am going to respectfully disagree with this.  I have about 45 years driving experience, northeastern Pennsylvania/southwestern Pennsylvania/Western Maryland, so I have seen and driven in my share of snow.
I will take a 4 wheel drive/all wheel drive vehicle with fair all weathers to a rear wheel drive vehicle, especially a lightly loaded pickup truck, with snow tires.  A small pickup, like a Comanche or Chevy S10, even with brand-new snows, is about worthless with just rear wheel drive.
Put quite a bit of weight in back, totally different story.  For a while we lived in a house with a fairly steep gravel driveway with a hairpin turn halfway up.  A local excavator, who kept gravel on site, was about 2 miles away.  When our driveway would ice up, I would go to the excavator, get about a ton of gravel in the Comanche, and have exceptional traction in rear wheel drive.
Any one else's thoughts on this?
Gene
52 minutes ago, Gene said:
Hi Pete,
Gene
but what 2wd pickup doesn't have a ton of weight in the back for winter?  :dunno:   Back in its 2wd days I used to go out and hit the roads before the plow trucks came.  :D  and those weren't even snow tires, just new BFG ATs.
besides, stopping and turning are more important than acceleration.  snow tires for the win!! :comanche:
Not when you get dumped on bad lol. I will take 4x4 with bad tires all day lol. I have 6 sandbags in now and as soon as I hit an ice patch on the right rear I'm stuck and spinning. I feel like an idiot getting stuck in my driveway with a foot of snow lol but there is 2 in of ice under it lol
