Searching online for an inner shift boot for my comanche, can’t seem to locate a specific one (non look like the one i removed) curious if anyone’s used a different style/kind with good results?
I don't believe the one used from 84-90 or whatever is available.  The later one is, and it will fit but the screw holes do not line up.  It also allows for the hole in the floor for the shifter/tower to be cut out much more, which was why they went to that style.  Crown and Dorman make the later one, I believe.
Thank you, that was all i was finding, figured i could use it but maybe hidden somewhere there was an oem one
