Plastic under front bumper
What the hell is the plastic trim piece underneath the front bumper called? I tried to get one from a Cherokee at pull a part but they were all already taken.
Mine is all wonky so I wanted to replace it. Are they supposed to be flat or have some curve to them?
Thanks!
I'm either going to attempt to straighten mine out with a heat gun or just not put it back on and trim the very bottom piece of fender flare so it doesn't look like something is missing. Decisions decisions...
If I fail at straightening it and decide I still want one I may be interested HOrnbrod.
I disagree. But it's your truck and you can hack it up any way you like.   :L:
The purpose of the air dam is mainly for better engine cooling. It creates a low pressure zone on the engine side of the radiator that reduces underbody turbulence and helps to increase CFM airflow through the radiator for better engine cooling at highway speeds.
BUT it does nothing to help improve the aerodynamics of our brick-like trucks to improve mileage. Edited just now...
The purpose of the air dam is mainly for better engine cooling. It creates a low pressure zone on the engine side of the radiator that reduces underbody turbulence and helps to increase CFM airflow through the radiator for better engine cooling at highway speeds. It does nothing to help improve the aerodynamics of our brick-like trucks.
So you are saying that airdams normally serve a purpose but in Comanches it doesn't do much?
19 hours ago, JMO413 said:
The OEM all had a number change and went to 5AH08JX9. They are available aftermarket.
Those are junk - another flimsy POS C.R.A.P. part.
The XJ/MJ front air dam went through several part number changes, the last being 5EV24SX9 for the 1996 XJs. They are all interchangeable and compatible from 84-96.
Nope. Read it again. I said it does nothing for the MJ aerodynamics, or lack thereof.
But it does help with engine cooling at speed..
