kook911 Posted October 1, 2018 Share Posted October 1, 2018 I did the headlight harness on the old MJ. When I try to use the highs nothing happens as the lights just go out. The low beam work no problem. Any ideals on why this is happening. Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted October 1, 2018 Share Posted October 1, 2018 Bad or misadjusted dimmer switch on the column would be a good start Link to comment Share on other sites More sharing options...
Dixie Posted October 1, 2018 Share Posted October 1, 2018 Did they work prior to the harness? Do the high beam indicators come on in the instrument cluster? Link to comment Share on other sites More sharing options...
kook911 Posted October 1, 2018 Author Share Posted October 1, 2018 10 minutes ago, Dixie said: Did they work prior to the harness? Do the high beam indicators come on in the instrument cluster? Work perfectly until I install the harness. I also install the same harnesss on my XJ and everything works like it should. Link to comment Share on other sites More sharing options...
SVPete Posted October 1, 2018 Share Posted October 1, 2018 Did the harness come with two relays? Maybe try swapping the relays? If the lows stay off and the highs come on, that is likely the problem. Link to comment Share on other sites More sharing options...
Minuit Posted October 1, 2018 Share Posted October 1, 2018 Yeah, you might want to check the relays. Some of those harnesses come with some nasty relays. I swapped the relays in mine out with some nice OEM relays and always keep a spare around. That's the only thing that could almost be called a downside of adding the relay harness - you've added a single point of failure that can shut down your high beams or low beams. Course, your headlight switch catching on fire might shut down more than just your headlights. Link to comment Share on other sites More sharing options...
kook911 Posted October 1, 2018 Author Share Posted October 1, 2018 7 hours ago, SVPete said: Did the harness come with two relays? Maybe try swapping the relays? If the lows stay off and the highs come on, that is likely the problem. I’ll will try that this afternoon after work and see if that fixes the problem. Link to comment Share on other sites More sharing options...
SVPete Posted October 3, 2018 Share Posted October 3, 2018 Any resolution? Link to comment Share on other sites More sharing options...
kook911 Posted October 5, 2018 Author Share Posted October 5, 2018 On 10/2/2018 at 8:12 PM, SVPete said: Any resolution? Swapped the relays and still not working. I’m guessing I will take it apart and see what is going on. Got to get it figured out to pass inspection. Link to comment Share on other sites More sharing options...
Dixie Posted October 5, 2018 Share Posted October 5, 2018 I had the same problem and it turned out to be a frayed wire. Purple with a white tracer. Does the high beam light in the gauge cluster turn on when you switch it on, at least? Link to comment Share on other sites More sharing options...
kook911 Posted October 5, 2018 Author Share Posted October 5, 2018 23 minutes ago, Dixie said: I had the same problem and it turned out to be a frayed wire. Purple with a white tracer. Does the high beam light in the gauge cluster turn on when you switch it on, at least? Yea it turns on when switched on. Link to comment Share on other sites More sharing options...
Dixie Posted October 5, 2018 Share Posted October 5, 2018 You can try checking that purple/white wire and see the condition of it. Hopefully the guys have more suggestions before you have take it apart. Link to comment Share on other sites More sharing options...
SVPete Posted October 6, 2018 Share Posted October 6, 2018 In order to pass inspection, can't you simply restore it to the original configuration since it was working before you installed the supplemental harness? That would be the best troubleshooting option at the moment. If the headlights work properly again, then you received a bad harness that you can return for replacement. Link to comment Share on other sites More sharing options...
kook911 Posted October 6, 2018 Author Share Posted October 6, 2018 3 hours ago, SVPete said: In order to pass inspection, can't you simply restore it to the original configuration since it was working before you installed the supplemental harness? That would be the best troubleshooting option at the moment. If the headlights work properly again, then you received a bad harness that you can return for replacement. yes I can do that. My inspection isn't until January of next year so I got some time. I will take it apart and see if I nicked a wired on the install and go from there. Worst case is i just uninstall it and call it a day. Link to comment Share on other sites More sharing options...
cruiser54 Posted October 6, 2018 Share Posted October 6, 2018 Double check the grounds for the relays. Have to be connected to clean and shiny metal. Link to comment Share on other sites More sharing options...
