mancheflo Posted September 26, 2018 Share Posted September 26, 2018 Has anyone ever upgraded their gauges? I don’t have a rpm gauge or any actual temp guage but was thinking of doing like the gauge set on the side Link to comment Share on other sites More sharing options...
Minuit Posted September 26, 2018 Share Posted September 26, 2018 There are full 6-gauge clusters available that will be a direct swap into your truck with very little other work - just swapping a pair of sensors. If you tell us a little more about your truck and your plans we can be more helpful. Link to comment Share on other sites More sharing options...
Jeep Driver Posted September 26, 2018 Share Posted September 26, 2018 Just finished wiring mine up tonight. There are always options. Link to comment Share on other sites More sharing options...
Eagle Posted September 26, 2018 Share Posted September 26, 2018 As Minuit commented, the XJs and MJs are prewired to work with full gauges, all you need is a cluster out of a compatible year. Yours is an 86? So you need one with a mechanical speedometer -- they changed to an electronic speedometer in 1991. The speedometer cable connection to the actual speedometer changed in 1987, so the easiest for you would be a cluster out of an 84-86 XJ or an 86 MJ. You can also use a cluster from an 87-90 XJ or MJ, but you'll have to replace the speedometer cable with the newer type. There should be several discussions on here about swapping the cluster. Try a search. Link to comment Share on other sites More sharing options...
mancheflo Posted September 26, 2018 Author Share Posted September 26, 2018 1 hour ago, Eagle said: As Minuit commented, the XJs and MJs are prewired to work with full gauges, all you need is a cluster out of a compatible year. Yours is an 86? So you need one with a mechanical speedometer -- they changed to an electronic speedometer in 1991. The speedometer cable connection to the actual speedometer changed in 1987, so the easiest for you would be a cluster out of an 84-86 XJ or an 86 MJ. You can also use a cluster from an 87-90 XJ or MJ, but you'll have to replace the speedometer cable with the newer type. There should be several discussions on here about swapping the cluster. Try a search. Mines a 92 Link to comment Share on other sites More sharing options...
Minuit Posted September 26, 2018 Share Posted September 26, 2018 58 minutes ago, mancheflo said: Mines a 92 Then it'll be easy. The full gauge cluster from any 1991-1996 Cherokee or Comanche is a direct swap. You'll need the accompanying gauge sending units - one for oil pressure, and one for temperature. The correct full cluster looks like this, and has a white casing. Link to comment Share on other sites More sharing options...
Eagle Posted September 26, 2018 Share Posted September 26, 2018 1 hour ago, mancheflo said: Mines a 92 I knew that, I was just testing you. Link to comment Share on other sites More sharing options...
bad_idea Posted September 26, 2018 Share Posted September 26, 2018 Looks like everyone answered your question. I swapped the cluster in my 90 XJ when I got it, happy with it. Very simple. Just need to swap out the cluster, water temp sensor, and oil pressure sensor. There are two water temp sensors (on my 90 XJ anyways, not sure about your 92) - one for the gauge and one for the fan. Also, let me suggest you put your vehicle info in your signature line. Saves you from typing it out every post. Link to comment Share on other sites More sharing options...
Tex06 Posted September 26, 2018 Share Posted September 26, 2018 16 hours ago, Jeep Driver said: Just finished wiring mine up tonight. There are always options. Driver, other than your speedo being backwards I like that setup. Do you have a little more info on it? Link to comment Share on other sites More sharing options...
Jeep Driver Posted September 27, 2018 Share Posted September 27, 2018 18 hours ago, Tex06 said: Driver, other than your speedo being backwards I like that setup. Do you have a little more info on it? See my build thread. I'll do one more vid after it's installed. Link to comment Share on other sites More sharing options...
