dustytony Posted September 14, 2018 Share Posted September 14, 2018 Will 255/70R18s on wrangler rims fit a stock manche front end? Found a good deal and wanna know if they will Work right away or not. Link to comment Share on other sites More sharing options...
dvitha Posted September 14, 2018 Share Posted September 14, 2018 That is about a 32 inch tire at 10 inch wide. I know 10.5's will rub when full turn locked on stock setup. here at the shop on our jeeps with the 4.10's we do 30/9.5r15s with no lifts . I know the 32s will fill the hell out of the stock wheel well with no lift Link to comment Share on other sites More sharing options...
Jeep Driver Posted September 14, 2018 Share Posted September 14, 2018 Your short answer is- No. And they will be 5x5 so you'll have to use adapters which will throw you out another 5/4". Link to comment Share on other sites More sharing options...
dasbulliwagen Posted September 15, 2018 Share Posted September 15, 2018 I had a set on mine for a long time with little to no lift in the front. I say little to no, because when I did my 4x4 conversion I added the 4wd springs and an extra isolator, so I might have had 1/2" lift, and used shackles in the rear on the original 2wd rear springs. They did rub, especially when backing up and turning, or under a heavy load, especially in the rear. But they were usable and I ran it like that for 3-4 years. I'm lifted now so the rubbing isnt an issue anymore. I'm also at 4:10 gearing, so that helped as well. I can't see running these with any less gearing, especially with a 4 cylinder like mine. Link to comment Share on other sites More sharing options...
dasbulliwagen Posted September 15, 2018 Share Posted September 15, 2018 here's mine with the front unlifted. As you can see, the 32's fill the wheel well good. Link to comment Share on other sites More sharing options...
dustytony Posted September 15, 2018 Author Share Posted September 15, 2018 here's mine with the front unlifted. As you can see, the 32's fill the wheel well good. Great man thanks. Mine has the rear springs on top so I’m just worried about the front. I went ahead and got them cuz I figure I’ll find somebody that would want them if I can’t get it to work. Link to comment Share on other sites More sharing options...
Jeep Driver Posted September 15, 2018 Share Posted September 15, 2018 32s with 2.5" lift.........work out great if you don't need to steer. Yours is stock height from what I gather. Link to comment Share on other sites More sharing options...
dustytony Posted September 15, 2018 Author Share Posted September 15, 2018 Yeah I’ll probably go a different route. That being said, what’s a fair price for a set of about half tread left 255/70R18s on wrangler rims with a brand new spare? Link to comment Share on other sites More sharing options...
dustytony Posted September 15, 2018 Author Share Posted September 15, 2018 Link to comment Share on other sites More sharing options...
Jeep Driver Posted September 15, 2018 Share Posted September 15, 2018 can't' answer your question on price but I'd guess $200. Learn from my mistakes............... Decide what you want from the beginning, incrementalism is expensive. Those wheels and tires cost me $2000+ and now I'm about to order a new set at $2500. And there have been several sets on the truck prior. If you want big, go big from the beginning or pay and pay and pay again, like I've done. I wouldn't buy those wheels myself, IINM, those are 7" wheels. Lot of guys run 12" tires on 7" wheels, I won't, it's a hack in my opinion. Link to comment Share on other sites More sharing options...
dustytony Posted September 15, 2018 Author Share Posted September 15, 2018 Yeah I’m not trying to add a lift or anything long term, just wanted a little more tire. Thanks for the info and response! Link to comment Share on other sites More sharing options...
yxmj Posted September 16, 2018 Share Posted September 16, 2018 Like mentioned above....rubber will fit under the. Truck....but if those are like you say "wrangler" rims...the bolt pattern is different... what am I missing? Link to comment Share on other sites More sharing options...
kryptronic Posted September 16, 2018 Share Posted September 16, 2018 19 hours ago, dustytony said: Yeah I’ll probably go a different route. That being said, what’s a fair price for a set of about half tread left 255/70R18s on wrangler rims with a brand new spare? You can get 5 JK take-offs around here, tires on rims, for around $400 a set on CL or FB. Typically 2000-3000 miles on Bridgestone Duelers or Goodyear Wranglers is what you see available. Link to comment Share on other sites More sharing options...
