Tire question
13 Legion
Right Pete. We measured them yesterday and they were roughly 34 in height. So does that make it a 35? Just asking because when I hear 31’s, 33, 35s is that a standard measurement or is say a 31 actually taller or shorter than actual measurement. Thanks Krusty as well!
Tires are almost never exactly the height they are measured at.  Some companies run slightly larger than advertised and some slightly smaller.  At 34.4" it would either be advertised as 34", 35", or even 34.5" depending on the company that made them.
They're basically 35s.  I debated on 315/75R17 vs 35x12.5x17 for my JKUR.  All the research I did showed the 315s as slightly smaller.  Very, very slightly.  Here are 35s on mine with a 2" OME lift and PSC flats:
FYI, they measure 34.25" installed on wheels with AEV specs at 32 PSI.
