kill_burst Posted August 8, 2018 Posted August 8, 2018 I have some serious SSG on my drivers side door. Want to make them half doors and figure I might as well fix the pins and bushings while I’m at it. I believe the bushing wore out and that’s what’s causing my issue. Anyone have any luck finding the correct pins? Seems like all I can find are the 97+ pins. Any help would be appreciated.
DirtyComanche Posted August 8, 2018 Posted August 8, 2018 They're just a 1/4" roll pin, IIRC. Maybe they're 3/16"? Sorry, I don't remember. I drill the hinge the next size over and put a bolt in when I make the doors quick removable, and I would probably do that even if I wasn't making them removable.
HOrnbrod Posted August 8, 2018 Posted August 8, 2018 5 minutes ago, DirtyComanche said: They're just a 1/4" roll pin, IIRC. 1/4" si.
SVPete Posted August 8, 2018 Posted August 8, 2018 Or just use standard 1/4 inch bolts (pretty sure that's the size). I slipped a thin washer in between the hinge pieces and snugged the bolts. It put a good cure on the sag I had. I tried just replacing the pins which I had pulled from the rear doors of a Cherokee in the JY. Figured less wear on the rear doors. But It didn't work out. The bolts were a lot better.
DirtyComanche Posted August 8, 2018 Posted August 8, 2018 1 minute ago, SVPete said: Or just use standard 1/4 inch bolts (pretty sure that's the size). I slipped a thin washer in between the hinge pieces and snugged the bolts. It put a good cure on the sag I had. I tried just replacing the pins which I had pulled from the rear doors of a Cherokee in the JY. Figured less wear on the rear doors. But It didn't work out. The bolts were a lot better. I only drill them a size over because normally the holes are oblonged. It's a case by case thing. I also tried using metric bolts that were just a hair bigger, along with high tolerance bolts (also a hair oversize).
Jeep Driver Posted August 8, 2018 Posted August 8, 2018 2 hours ago, DirtyComanche said: I only drill them a size over because normally the holes are oblonged. It's a case by case thing. I also tried using metric bolts that were just a hair bigger, along with high tolerance bolts (also a hair oversize). A blonde hair?
kill_burst Posted August 8, 2018 Author Posted August 8, 2018 Great info. So no need to replace bushing? Just go with the 1/4 inch bolt.
Wounded_Fighter Posted August 8, 2018 Posted August 8, 2018 4 hours ago, Jeep Driver said: Is that stress fracturing I see? or paint damage from grip on a wrench/vice? lol
