after about a year and a half, I'm finally finishing up the 4.0 swap into my fathers 86 Comanche. Being my first engine swap, it never occurred to me to label any of the electrical connectors as I took them all off. I found a home for most of them but I'm a little lost on four of them. Any help identifying them would be greatly appreciated. The first two are located near the battery. I think the large one might be a factory fog light connector. The third one is on the other side of the engine bay near the computer. That one possibly might be a diagnostic port. The last one is on the back firewall near the intake manifold. No clue on that one. Any help would be appreciated.:L:
That looks like an ODBI diagnostic connector. The electric fan relay is on the header clip LH side of the radiator. It usually has a plastic holder for the connector and the relay plugs into it.
You guys nailed it.
Thanks guys! That's one off the list of things I have to worry about haha The engine came out of a 96 cherokee 4.0 sport. It came from someones field half complete for 350$.
Are you sure it was a '96? 1996 was the year the Cherokee first came with OBD2, which used a standard OBD2 'D' connector under the dashboard. 1995 was still OBD1.
