ComancheCrusher9800 Posted June 28, 2018 Share Posted June 28, 2018 Alright so I haven't posted in a while, since my Comanche was running. But I blew the motor about a year ago and am just now getting to replace is. The one I am putting in is a 2.5l out of a 2000 Cherokee. I am using just the motor and putting my flywheel, clutch and transmission, etc. But I want to use the intake and exhaust off of the 2000 but the Throttle body off of my Comanche will not fit on the Cherokee intake. Does anyone make an adapter for it? Or has anyone ever done it? Sent from my SM-G900V using Tapatalk Quote Link to comment Share on other sites More sharing options...
Jeep Driver Posted June 29, 2018 Share Posted June 29, 2018 Quote Link to comment Share on other sites More sharing options...
8valvehero Posted June 29, 2018 Share Posted June 29, 2018 This looks like a cool project. I can’t do much to help with your issue, but please post pics to satisfy curiosity! Quote Link to comment Share on other sites More sharing options...
cruiser54 Posted June 29, 2018 Share Posted June 29, 2018 They're 2 completely different fuel injection systems. Just use your stuff. Quote Link to comment Share on other sites More sharing options...
Jeep Driver Posted June 29, 2018 Share Posted June 29, 2018 23 minutes ago, cruiser54 said: They're 2 completely different fuel injection systems. Just use your stuff. You notice I didn't type anything in my post? Don't stifle the spark of creativity and imagination. Quote Link to comment Share on other sites More sharing options...
ComancheCrusher9800 Posted June 30, 2018 Author Share Posted June 30, 2018 Did you make the adapter or did you buy it? It looks easier than the way I was thinking first. You took the original all thread out and used bolts to put it in and used new ones to adapt your TB to. I like that idea. All I would really need it a piece of plate. But what did you use?Sent from my SM-G900V using Tapatalk Quote Link to comment Share on other sites More sharing options...
Jeep Driver Posted June 30, 2018 Share Posted June 30, 2018 1/2" aluminum plate. You get 5pcs for $20 on ebay. You'll screw up one or two, trust me, if you are doing by hand as I did. 4"x4".....something like that. Been a while. And you'll need to tap the injector holes, 9/16 tap and plugs, you'll need two taps, one to make a bottom tap. Quote Link to comment Share on other sites More sharing options...
ComancheCrusher9800 Posted June 30, 2018 Author Share Posted June 30, 2018 What year model do you have? 1/2" aluminum plate. You get 5pcs for $20 on ebay. You'll screw up one or two, trust me, if you are doing by hand as I did. 4"x4".....something like that. Been a while. And you'll need to tap the injector holes, 9/16 tap and plugs, you'll need two taps, one to make a bottom tap. Sent from my SM-G900V using Tapatalk Quote Link to comment Share on other sites More sharing options...
Jeep Driver Posted June 30, 2018 Share Posted June 30, 2018 The block is a 98 and the intake....?????, don't remember, 2000 maybe? The block and heads are all the same, intakes may vary but I doubt it, just look around. Quote Link to comment Share on other sites More sharing options...
Jeep Driver Posted June 30, 2018 Share Posted June 30, 2018 Let me back up......... Maybe a 93 or 94 intake, has to do with the PS mount. I really don't remember, you'll have to study it out, I began building the engine 4 years ago. Quote Link to comment Share on other sites More sharing options...
ComancheCrusher9800 Posted June 30, 2018 Author Share Posted June 30, 2018 Let me back up......... Maybe a 93 or 94 intake, has to do with the PS mount. I really don't remember, you'll have to study it out, I began building the engine 4 years ago. What year Comanche do you have? Are you using the original wiring harness?Sent from my SM-G900V using Tapatalk Quote Link to comment Share on other sites More sharing options...
MeanLemons Posted June 30, 2018 Share Posted June 30, 2018 The adapter plate look interesting. Shouldn’t be too hard to make Quote Link to comment Share on other sites More sharing options...
Jeep Driver Posted July 1, 2018 Share Posted July 1, 2018 5 hours ago, ComancheCrusher9800 said: What year Comanche do you have? Are you using the original wiring harness? Sent from my SM-G900V using Tapatalk 1988, yes, original wiring. Quote Link to comment Share on other sites More sharing options...
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
