HELP NEED BOLT SIZES!!!
New member her been lurking a while till i found my comanche. well finally found it and the PO said it needed a new crankshaft position sensor. well i got underneath to look and the sensor is missing a bolt and the sensor is broken. so i ordered a new sensor and don't know what the size is. the sensor is still in the comanche. but going to replace it this evening when i get home.So does anyone happen to know the size of that bolt? threads and length? its a 88 comanche 4.0 manual 4x4 short box. also it looks like its going to be a pain to replace I'm thinking of just making an access panel on the floor board for future sensor replacement. thanks for the help
The head of the bolt is 7/16.....by about 1/2"
Before you chop a hole in the floor get together your longest socket extentions .....it is easier when your ratchet is back near the tail of the trans......sometimes a helper in the engine bay guiding the socket comes in handy
16 minutes ago, Jeep Driver said:
Those are very specific shoulder bolts the head is 11 mm and I don't think it's quarter 20 thread
I’m a machinist and welder by trade guess I need to get to making 2 of them. The one bolt that is still there is not a factory bolt don’t look like it.
Machine about a hundred of them. You'll sell every one in about an hour....
Here's another pic from Cruiser
You could try you local JY......they might have trans with bolts in that you could scavenge .....
And IMHO....it would be easier to re-tap the hole to a common thread, then just use an off the shelf bolt, quicker than making bolts?
check the fuel pump resistor (3" whitish ceramic block with 2 wires coming out of it on the drivers side of the engine bay).  power is routed straight to the pump during cranking and then diverted to run through the resistor a second later to lower the voltage at the pump and quiet it down a tad.
ok ill try that this evening thanks , just check it with a meter? truck has been sitting for a couple of years the PO said all  it needed was a CPS but yall know how that goes. the CPS was damaged, i don't know if he broke it trying to take it out or what, but anyways it has a new one now.
check if it's even connected.  it's reeeeeal easy to knock off one of the wires (it was a halfass fix for complaints about a loud fuel pump)   if the wires are on and corrosion-free, then check for cracks or other damage.
