dkenitz Posted April 17, 2018 Posted April 17, 2018 Hi all, First, I'm very glad to have found this forum!! I've been doing a lot of searching and reading here, and I'm blown away by the knowledge and 'niceness' of the members (special thanks to Cruiser54)! I recently purchased an '88 Comanche 2wd (4.0/5spd Renix). The truck is running extremely rough, except at idle. With any amount of throttle (though I don't believe I've floored it yet), the motor will stumble, misfire, and today for the first time, I heard a backfire. So far I have: cleaned the dipstick ground and associated terminals, replaced both battery cables, replaced (and adjusted) the TPS that was not sweeping smoothly, replaced the firewall ground per Cruiser54's tip, throttle body appears to have been recently cleaned, the MAP hose is good per my quick mouth vacuum test, cleaned out the C101 connector, and used contact cleaner on all the electrical connections I could find in the engine bay. I still need to do the sensor ground upgrade and eliminate the C101 connector as I get variable resistance when wiggling the wire harness as well as C101 connector. I also have ordered the vacuum harnesses as there are multiple broken and missing vacuum lines (see pics). There are mangled wires running to the distributor as well which I need to replace (see pic). After doing some more reading I have removed the valve cover and attempted to check the distributor indexing as it appears the cap and wires were recently replaced. I'm not sure if the distributor itself is new or old but I'm thinking it could be old as it says "Lucas" on the sticker (see pic). I removed the cap and checked for rotor alignment at TDC but stopped before actually re-indexing the distributor. The rotor appears to point at 5 o'clock when at TDC, which seems correct. If it was off a couple teeth could that cause the extremely rough running? I'm wondering if I should go ahead index the distributor (or replace if necessary), or if I should wait until I have eliminated the C101 connector and sensor ground upgrade? Also, one of the two throttle body holes is open (see pic). Is a vacuum line supposed to go there as well? Am I missing anything obvious in figuring out this rough running issue? Any advice would be appreciated. Thanks in advance! Dustin 20180417_122913(1).mp4
fiatslug87 Posted April 17, 2018 Posted April 17, 2018 Welcome to the Club. Check the functioning of the EGR and that "extra hole" in the TB is plugged (that rubber piece doe not have a hole at that position).
dkenitz Posted April 18, 2018 Author Posted April 18, 2018 Thanks for the suggestion Slug! I've come across some posts on temporarily plugging the egr valve vacuum hose in order to keep it closed and check for improvement. Would that work in this case? If so, which hoses/ports specifically do I need to block off? The separate vacuum transducer is confusing me a bit. Dustin
cruiser54 Posted April 18, 2018 Posted April 18, 2018 You need to do the obvious fixes first. Vacuum harnesses for instance. and wiring repairs. No butt connectors!! You can just plug off the vacuum to the EGR for now. If it were hanging open, your idle would be horrible. Not to shift gears too far, backfiring under load can be a sign of a weak fuel pump.
dkenitz Posted April 18, 2018 Author Posted April 18, 2018 Thanks for chiming in cruiser! I'm waiting on NAPA to let me know the vacuum harnesses are in and I'll be doing the sensor ground upgrade hopefully tomorrow. Is there anything else obvious I'm missing at this time? Dustin
dkenitz Posted April 20, 2018 Author Posted April 20, 2018 Latest update: installed all new vacuum hoses including CCV (minus MAP for now), bypassed the fuel ballast resistor, changed the spark plugs to NGK 7252 (found a mix of 5x NGK BKR5ES and 1 random Champion), and inspected the sensor grounds...though ran out of time to solder them together as well as eliminate the C101 connector. The sensor grounds looked good though. I will still solder them together as well as eliminate the C101 (hopefully tomorrow) but I was surprised how non-corroded and healthy they looked. On the first start the motor revved fairly freely without the hesitation and missing as it did before. I got excited, but after a few mins the hesitation and sputtering returned with throttle application. I did floor it once and it hesitated but did start revving freely. I also measured the fuel pressure at the rail today. At idle the pressure was ~29 psi (+/- 0.5 psi) and with the FPR vacuum line unplugged, the pressure was 38 psi. I believe the specs are 31 psi @ idle and 39 psi with the vacuum line detached. Do these values indicate the fuel pump is failing? Dustin
Kyleinreallife Posted April 20, 2018 Posted April 20, 2018 Latest update: installed all new vacuum hoses including CCV (minus MAP for now), bypassed the fuel ballast resistor, changed the spark plugs to NGK 7252 (found a mix of 5x NGK BKR5ES and 1 random Champion), and inspected the sensor grounds...though ran out of time to solder them together as well as eliminate the C101 connector. The sensor grounds looked good though. I will still solder them together as well as eliminate the C101 (hopefully tomorrow) but I was surprised how non-corroded and healthy they looked. On the first start the motor revved fairly freely without the hesitation and missing as it did before. I got excited, but after a few mins the hesitation and sputtering returned with throttle application. I did floor it once and it hesitated but did start revving freely. I also measured the fuel pressure at the rail today. At idle the pressure was ~29 psi (+/- 0.5 psi) and with the FPR vacuum line unplugged, the pressure was 38 psi. I believe the specs are 31 psi @ idle and 39 psi with the vacuum line detached. Do these values indicate the fuel pump is failing? Dustin Where is the fuel ballast resistor? I’m starting to think my issue may also be vacuum related 87 XJ Wagoneer Ltd I-6 NP242 AW4 HPD30/D44
dkenitz Posted April 20, 2018 Author Posted April 20, 2018 It's on the driver's fender side of engine bay:
Kyleinreallife Posted April 20, 2018 Posted April 20, 2018 It's on the driver's fender side of engine bay: Gotcha thanks. I’m having the same issue as you except I’ve already replaced the vac lines, tps, egr, map, iac, cap, rotor, plugs, wires....I’m thinking maybe I didn’t hook the vac lines back up properly 87 XJ Wagoneer Ltd I-6 NP242 AW4 HPD30/D44
cruiser54 Posted April 21, 2018 Posted April 21, 2018 An FYI, at the dealership we replaced plugs, wires, cap and rotor every 30,000 miles. Wires were only specified every 60,000 but we found they didn't make it that long.
dkenitz Posted April 21, 2018 Author Posted April 21, 2018 Thanks for that information, I'll go ahead and order new wires, cap, and rotor since I have no idea how old they are. Cruiser, what do you think of those fuel pressure readings above? Close enough to spec to rule out a fueling issue? Also, could you recommend specific wires, cap, and rotor? Is local auto parts store quality good enough?
dkenitz Posted April 22, 2018 Author Posted April 22, 2018 I'm starting to believe the issue is a dying fuel pump. After I first start the motor, it will rev freely (and sounds perfect) for the first set of throttle blips. Then the sputtering, backfiring, hesitation returns. At this point I plan on ordering: Taylor 84048 wires, AutoZone's Duralast Gold distributor cap w/rotor (brass terminals), and a Carter P74155 fuel pump kit. Thoughts?
Ωhm Posted April 23, 2018 Posted April 23, 2018 When you connected the fuel pump pressure gauge was the vehicle sputtering and backfiring while you were taking your readings? Were the gauge readings steady during this or bouncing around? Gauge you used could be reading low. Also connect voltmeter across the fuel pump ballast resistor and see if voltage changes during sputtering, backfiring and hesitation. What is the voltmeter reading? Ohmmeter the ballast, could be faulty. What is the ohmmeter reading? Wiggle contacts.
Kyleinreallife Posted April 23, 2018 Posted April 23, 2018 Look inside the distributor cap for carbon tracking. What does the ballast resistor do?87 XJ Wagoneer Ltd I-6 NP242 AW4 HPD30/D44
Kyleinreallife Posted April 23, 2018 Posted April 23, 2018 What does the ballast resistor do?87 XJ Wagoneer Ltd I-6 NP242 AW4 HPD30/D44 Mine is absent...87 XJ Wagoneer Ltd I-6 NP242 AW4 HPD30/D44
Ωhm Posted April 23, 2018 Posted April 23, 2018 Its sole purpose is to drop voltage between the battery and the fuel pump. When 4.0L was first introduced (without ballast), people complained pump was too noisy. The ballast helped quiet it down. Has no affect on pump requirements. Ballast is bypassed during crank and WOT.
HOrnbrod Posted April 23, 2018 Posted April 23, 2018 Check the fuel pump ground behind the left tail lamp.
HOrnbrod Posted April 23, 2018 Posted April 23, 2018 20 minutes ago, Ωhm said: Ballast is bypassed during crank and WOT. I had to look this up. And yes, normal 12V power to the pump drops across the ballast resistor and another 12V power source bypasses the resistor depending on the FP relay contact positions when starting or at WOT when the O2 sensor also drops out. I never realized this about the pump - good to know.
Kyleinreallife Posted April 23, 2018 Posted April 23, 2018 Check the fuel pump ground behind the left tail lamp. Will do87 XJ Wagoneer Ltd I-6 NP242 AW4 HPD30/D44
dkenitz Posted April 23, 2018 Author Posted April 23, 2018 2 hours ago, Ωhm said: When you connected the fuel pump pressure gauge was the vehicle sputtering and backfiring while you were taking your readings? Were the gauge readings steady during this or bouncing around? Gauge you used could be reading low. Also connect voltmeter across the fuel pump ballast resistor and see if voltage changes during sputtering, backfiring and hesitation. What is the voltmeter reading? Ohmmeter the ballast, could be faulty. What is the ohmmeter reading? Wiggle contacts. Here is a video of one test where I was blipping the throttle and it's sputtering. After this test the gauge stopped registering any pressure, even with the engine idling. So, not sure how accurate the gauge was in this video. https://www.dropbox.com/s/banipl81c2wyj4o/20180422_155524.mp4?dl=0
dkenitz Posted April 23, 2018 Author Posted April 23, 2018 Also I have bypassed the ballast resistor in an attempt to simplify things.
Ωhm Posted April 23, 2018 Posted April 23, 2018 Video shows slow pressure build up when cranking and check valve holds no pressure when shut off. Check valve should hold pressure for at least one hour. Vehicle could be starving on fuel.
Ωhm Posted April 23, 2018 Posted April 23, 2018 Are your spark plugs fouling out rich? Could be leaky injector(s). Loss of fuel pressure on shut down.
dkenitz Posted April 23, 2018 Author Posted April 23, 2018 3 minutes ago, Ωhm said: Are your spark plugs fouling out rich? Could be leaky injector(s). Loss of fuel pressure on shut down. I just changed the plugs out for fresh ngk 7252's. No change at all in symptoms. Would that answer the fouled plug question? I'm not sure how else to test for that other than visually inspecting the plugs.
