Power Steering pump replacement ?
Hi guys,
Replaced my power steering pump but didn’t change the filter. The noise went away for a few weeks after I changed the pump but it’s back. Makes it when in motion and when I move the steering wheel. Any suggestions?
Unless someone added an external, there's no filter. Did you "bleed" the new pump after filling it with fresh fluid? You bleed it by starting it up after installation, then turning the steering wheel stop-to-stop in place until the reservoir stops bubbling air. What are you driving?
Yes sir!
1989 4.0 L, Automatic, Base Model
Yes. If someone could tell me how to post a picture on here I'd be in heaven and glad to show you as well as start many write ups. I don't know if its my cheap phone or what. I do not have a computer or digital camera, I use my phone for it all.
Sure! Are you using the tapatalk app for access to the club forum or using your main internet browser?
Tapatalk is the easiest by far to add pictures.
You simply start a thread and in the body of the thread there is a button to attach pictures or files etc.. you push that button and it accesses your phones picture library. Select the picture you want or multiples and hit send. Give them a minute to load and attach into the body of your message and once they load, hit the Go button or arrow or whatever is the enter button on your app. They should easily post in the thread, a reply within a thread or even a PM.
Is this helpful? Give it a shot in the test section of the forum!
Just replaced the PS pump on my 87 4.0.   The PS rebuilders recommend (or insist) that an in-line filter be placed in the return line  to the pump or it voids the warranty.
I got my pump from Rockauto and went with one remanufactured by Delco-Remy (at double the cost) because it was a Genersl Motors pump originally. Reading the description of the services it was more thorough than the others. My thought was they should know what they're doing because they made them originally. There are too many rebuilders out there taking shortcuts and putting out bad parts.
As a side nore, a sticker said it was remanned in Mexico and that's ok with me as long as it is quality work. So far, knock on wood, it's still good after 100 miles.
17 hours ago, HOrnbrod said:
Yes, they are used only on the 2.5's. Where does it screw into? Is there a "T" fitting on the high pressure hose?
It's an idle up switch and it's worthless and there's a greater chance that his idle control motor won't respond to it anyway
Yes, I know what it is, what it does, and why it's on the 2.5's. Just wanted to know how the switch is plumbed in....
