I have an 87 Wagoneer with the double stack front clip. Anyone have suggestions for alternate brighter lights? They’re slightly small than standard xj lights.
This is the direction the PO was going and it’s just not pretty and I’m pretty sure not legal
87' XJ Wagoneer I-6 AW4 NP242
don't forget a relay harness too.  :thumbsup:   (although I'm not sure if you need 2 of the ones in my sig or a different one)
I know truck-lite sells some 4x6 led headlights but kinda iffy on getting them due to the fact they don't have a heating element option and the with the weather here in ND you kinda need to be able to melt the snow off sometimes lol
Yes I would say that is or could be a real issue. he is in cali, I am in Texas, never a worry about that in our warm climates. They do make xenon kits that can be added. however they then need to put a relay since you risk melting the plugs wiring.
2 hours ago, Kyleinreallife said:
Can anyone suggest a decent way to polish up the front blinkers?
Toothpaste (especially gritty toothpaste) works well to clean up plastic headlights/turnsignals.  There are some products out there specifically designed for this also.
At least here in CO I have not yet had issues with headlights icing up with my LEDs.
