cruiser54 Posted December 7, 2018 Author Posted December 7, 2018 Got a top!!! Nice used assembly. High end fabric. all bolt in. No glue and crap. Have yet to drive it...
cruiser54 Posted November 15, 2021 Author Posted November 15, 2021 Long overdue updates on this car. And, I got another!! Mine is on the left. a buddy's is on the right. Below is a photo of the 78 Alfa Sport Sedan.
neohic Posted November 16, 2021 Posted November 16, 2021 20 hours ago, cruiser54 said: … 78 Alfa Sport Sedan. RAD!!
Pete M Posted November 16, 2021 Posted November 16, 2021 if I've learned anything from Top Gear, all Alphas are awesome
cruiser54 Posted November 16, 2021 Author Posted November 16, 2021 Pretty much. That unassuming sedan has about 150 HP, a close ratio 5 speed transaxle in the rear, DeDion rear suspension, inboard rear disc brakes, mechanical fuel injection, torsion bar front suspension. 50/50 weight distribution. Engine is a 2.0 liter DOHC crossflow hemi. All aluminum with steel cylinders. I modded it also. Poly bushings, big sway bars, Koni shocks, 11mm cams, header, lightened flywheel etc. Bumpers removed and body shaved to remove any evidence of those 75 pound weights at each end!!
