JeepcoMJ Posted August 3, 2007 Posted August 3, 2007 hey, will a trackbar off of a 89 4.0 pioneer shortbed work on a 86 2.8 longbed? the one on the 3800 is shot, the one that came off the 89 was replaced less than 2000 miles ago along with all balljoints, ujoints, brake pads, and upper control arms. so I guess I'd just like to get away with putting this one in the 3800, but they look a bit different...I assume they're the same or similar length and the only difference would be because they sit lower as a result of heavier engine and are therefore different in length by a half inch at most...
akamcbird Posted August 3, 2007 Posted August 3, 2007 gimme a couple days i just got the '86 back and i can check
feerocknok Posted August 3, 2007 Posted August 3, 2007 Pretty sure they're all the same. If not, they all interchange.
JeepcoMJ Posted August 4, 2007 Author Posted August 4, 2007 I'm just putting it in on sunday I think...the tracbar on the 3800 isn't safe for me to drive in speeds in excess of 45mph if I hit a bump...bumps make it death wobble side to side. I also think my UCA bushings are shot (still haven't replaced them...my engineering of the exhaust headers/manifolds means that I have to remove the driver's side one in order to remove the upper control arm bolts :( ) so I will be looking into that.
UNL1MTD Posted August 4, 2007 Posted August 4, 2007 They're all the same, AFAIK. x2 I bolted on the trackbar from my '05 wrangler onto the '87 comanche and it works fine. No difference in length at all, but the ball joint is greaseable, so thats a bonus.
Eagle Posted August 4, 2007 Posted August 4, 2007 There's no difference by engine. Between the 86-90 and the 91+ there is a tiny difference in length. We tried to measure it or see it one day up at the dealership and we couldn't see it, but when I put a '93 track bar on my '88 XJ the steering wheel was about a quarter turn off and had to be re-centered. Works fine, though.
