Lindsay Posted September 5, 2017 Posted September 5, 2017 My rear slider (made of plexiglass) has a pretty noticeable bow, so much so that water is getting in because of it. so i have two questions for it. 1: is it even possible to buy just the slider piece? and 2: does someone have the dimensions for it on hand? Thank y'all in advance
carnuck Posted September 5, 2017 Posted September 5, 2017 Can you see if the plexiglass can be swapped (maybe reversed) around or is it just too tall, making it bow? I wish I could afford to build my design for a power window for mine using the old power sunroof I had kicking around from a Grand Wagoneer.
Lindsay Posted September 5, 2017 Author Posted September 5, 2017 That's not a bad idea. when i get home I'll see if I can reverse it. thank you for the input
Dzimm Posted September 5, 2017 Posted September 5, 2017 3 or 4 pane slider? I've got a factory 3 pane I can measure. It's probably not available anywhere for purchase but you can have a piece of glass made to fit.
Sugarfoot Posted September 5, 2017 Posted September 5, 2017 My factory glass rear window is fine, but it has always been missing the locking latch. Anyone got a spare laying around or a suggestion?
Lindsay Posted September 5, 2017 Author Posted September 5, 2017 1 hour ago, Dzimm said: 3 or 4 pane slider? I've got a factory 3 pane I can measure. It's probably not available anywhere for purchase but you can have a piece of glass made to fit. i have the tree panel
carnuck Posted September 5, 2017 Posted September 5, 2017 1 hour ago, Sugarfoot said: My factory glass rear window is fine, but it has always been missing the locking latch. Anyone got a spare laying around or a suggestion? I found a universal one in my collection from the Help! Rack.
Sugarfoot Posted September 5, 2017 Posted September 5, 2017 Was it red packaging and had the help name on it? Was it adhesive mounting? I wonder if they have a catalogue. Thanks I'll check it out.
Strokermjcomanche Posted September 6, 2017 Posted September 6, 2017 The factory slider is all glass , not plexiglass . If you need a latch ,and it is a factory slider I may know where one is at ...,
Sugarfoot Posted September 6, 2017 Posted September 6, 2017 21 hours ago, Strokermjcomanche said: The factory slider is all glass , not plexiglass . If you need a latch ,and it is a factory slider I may know where one is at ..., I'm all ears. Can you PM me or just shoot me and email, jed101455@gmail.com
Lindsay Posted September 7, 2017 Author Posted September 7, 2017 On 9/5/2017 at 9:47 PM, Strokermjcomanche said: The factory slider is all glass , not plexiglass . If you need a latch ,and it is a factory slider I may know where one is at ..., where at???
Eagle Posted September 7, 2017 Posted September 7, 2017 On 9/5/2017 at 4:09 PM, Dzimm said: It's probably not available anywhere for purchase but you can have a piece of glass made to fit. No, you can't have one made. It's not flat, it's curved.
Dzimm Posted September 8, 2017 Posted September 8, 2017 6 minutes ago, Eagle said: No, you can't have one made. It's not flat, it's curved. I never noticed the slight curve in it but you can have curved glass made and you can have a flat pane of glass bent. It's just more expensive than a regular flat pane. It won't cost a whole lot more however since it's a very slight curve. Here's the measurements of the center pane of a factory 3 slider. 14 7/8" x 11 1/2" x 1/4" thick.
