I just scored a set of metal visors for my door windows. I think they're OEM? I paid 20 shipped for them so I think I got a good deal. How rare are they? And how do they mount? I haven't received them. They're shipping tomorrow. Just wanting to get everything together to install when they get here! :D
I've got three pair of the metal visors / rain guards , some were mopar and some were the ventshade brand . I wouldn't call them rare , but they don't show up often . They are held up with three clips on each side that go in between the window seal and door frame .
thanks! Are these clips still available? The guy I bought them from said no hardware was included so I'm not sure if they have the clips.
I never had to search for the clips , mine were all complete . Hornbrod may know as I know he has a pair of mopar ones .
I can take a pic of the clips tomorrow if you want me to ,...
that would be great, thanks!
I have a set of clips around somewhere - don't know if they are Mopar or aftermarket. I think I remember though that they didn't work with the factory Mopar visors.
Finally got the visors. They look good, just need paint. No clips though. How do the clips fit on? I'm going to rig them probably once I figure out how the stock clips worked. Theres no markings for manufacturer on them.
I doubt if you can rig these w/o clips. The clips are one or the other below depending on your visor type. My visors use the black clips on the right. You install them by rolling down the window, pulling the glass weather strip down from the top a couple of inches, then pushing the flat part up into the metal channel with the prongs facing down and on the outside. It takes three clips for each door. Then push the weather strip back up and roll the window up tight to press them the clips in tight. The visors have a channel on one side that the prongs clip onto, holding it in place. It's a bear sometimes to get all three clips clipped in, but once in the visor is firm. I have about eight of the shiny clips you can try - hopefully they will work on your visors. PM me your address if you want them. I only have three of the black ones left and need to keep them for spares.
I doubt if you can rig these w/o clips. The clips are one or the other below depending on your visor type. My visors use the black clips on the right. You install them by rolling down the window, pulling the glass channel down from the top a couple of inches, then pushing the flat part up into the channel with the prongs facing down and on the outside. It takes three clips for each door. Then push the window channel back up and roll the window up tight to press them flat in the channel. The visors have a channel on one side that the prongs clip onto, holding it in place. It's a bear sometimes to get the clips clipped in, but once in they are firm. I have about eight of the shiny clips you can try - hopefully they will work on your visors. PM me your address if you want them. I only have three of the black ones left and need to keep them for spares.
the only markings I've found on them is G59-RF and LF which leads me to believe they're from a Cherokee. I PM'd you, though!
I'm guessing these are Mopar visors then? The clips don't even come close to connecting them as you can slightly see (horrible camera sorry) or do I have them installed wrong?
Here's a pic of one of the clips looking up from the inside of the door. You can see the two clip prongs and how they clip on the visor.
Image Not Found
The Mopar shades were made by Vent-Shade. They were the same exact product.
Sorry it's taken me a little bit to post back, been busy working on my Contour and doing yard work for my ma lately so the Jeep is having to wait more. Jjjdx2N.jpg
This is with the clip mounted the other way in the window, the clip is a little blurry cause the sun was shining and I couldn't tell if the phone was focused or not.
The "prongs" on the clip don't fit too tightly on the visor when I install them like Hornbrods picture shows. But I think with some work I can make this work great.
  • 4 years later...
you still have an extra set by any chance?
does anyone know if the long L shaped pieces that fit the full piece windows work with a vented window? says 84-01 cherokee but picture shows one with a full window. as in an xj after 96
3 minutes ago, eaglescout526 said:
You can get them aftermarket still, but only for the XJ.
is it the L shaped ones for the front? i thought the mj just covered the main window and not the vent window
No there’s actual metal ones that just cover the window for the older doors. I’ll get a part number for ya in the morn.
would be appreciated!
Vent Shade made all of Jeeps stainless shades. My nos Jeep shades from the 60's where Vent Shade brand. I put some NOS ones in my 2 door XJ. I'll snap a pic of them installed and the instructions in a bit.
