ruralandalone Posted April 24, 2017 Share Posted April 24, 2017 Please forgive me if this is the wrong place to post this, but I'm a newbie, starting my first (and likely last ) comanche rebuild. Does anyone know of a reputable place to get : A parts book floor panels. These seem to be available as 2 peices per side (front and rear). I assume I need both? rubber for the doors that goes around the side windows. brake cables. I don't know what the proper name is for the parking brake cables that attach directly to the drums, but mine are clearly shot... Link to comment Share on other sites More sharing options...
Ataki Posted April 24, 2017 Share Posted April 24, 2017 Try http://morris4x4center.com Link to comment Share on other sites More sharing options...
R1. Posted April 24, 2017 Share Posted April 24, 2017 It might be worth your while to check a pick and pull junk yard to find a used set of brake cables. I am kind of partial to the Haynes manuals. Jeep Cherokee: 1984 thru 2001 - Cherokee - Wagoneer - Comanche ISBN: 1563925400 is the one I have. Link to comment Share on other sites More sharing options...
Keyav8r Posted April 24, 2017 Share Posted April 24, 2017 It would help to know something about your truck - year, model, engine, drive train. There are some manuals and parts lists floating around the forum that may be applicable to your MJ. Link to comment Share on other sites More sharing options...
SVPete Posted April 25, 2017 Share Posted April 25, 2017 Recommend to check Rockauto and Amazon for parts. Link to comment Share on other sites More sharing options...
ruralandalone Posted April 25, 2017 Author Share Posted April 25, 2017 Thanks for the replies. It is an 86, long box. I don't know much about the engine and drive train. The four cylinder engine, 4 wd. No tag on the rear axle, so I'm not sure what it is. Link to comment Share on other sites More sharing options...
jpdriver1 Posted April 25, 2017 Share Posted April 25, 2017 I like to have both manuals for my vehicles, sometimes there is slightly different information between them. Youtube helps too for actual how to's. Link to comment Share on other sites More sharing options...
DirtyComanche Posted April 25, 2017 Share Posted April 25, 2017 Rockauto.com is selling reprints of the actual factory service manuals for many years of Jeep vehicles. They aren't cheap, but they're worth 10x what they cost... Or look on ebay or use the ones linked off cruiser54's website. Link to comment Share on other sites More sharing options...
Whiz Posted April 25, 2017 Share Posted April 25, 2017 rubber for the doors that goes around the side windows. Are you referring to the weather stripping? I got mine from Pick a parts. Well most of it off Cherokees. Link to comment Share on other sites More sharing options...
ruralandalone Posted April 25, 2017 Author Share Posted April 25, 2017 Yes, I was referring to the window weatherstripping. I would have thought that this was a standard replacement items for most vintage cars. (None of my other restorations had windows) Link to comment Share on other sites More sharing options...
Whiz Posted April 25, 2017 Share Posted April 25, 2017 If you use the search i know there is more info with what years fit. I think i did also see some on rockauto. Sent from my SM-G930V using Tapatalk Link to comment Share on other sites More sharing options...
