87 MJ with 4.0L engine and BA 10-5 tranny.
Recently I took my MJ on a 1900 mile drive across the country. At about 950 miles I noticed it was running a little rough and had a slight knocking/ tapping sound at idle up to ~2500 rpm. I checked all fluids and topped everything off, including front and rear diff, transmission, transfer case, and engine oil. I also replaced the air filter because it had foamy, cream colored crap in it, basically soaking the entire thing. I am guessing it was extremely aerated oil and water.
Drove it the 950 miles back home. The tapping/ knocking sound was about the same. Sometimes it wouldn't be there, and at times it would get a little louder. I had no real choice, so I kept driving.
At about 1800 miles into the trip there was a snapping sound and the tapping/ knocking got a lot worse. I finished driving it home and parked it.
To my knowledge it was not producing any smoke from the tailpipe at any point. I never saw any kind of cloud behind me as I was driving.
Today I started looking at it. The brand new air filter has about 1/3 of the length soaked in oil, but not foamy and creamy like before, just plain oil. I drained the engine oil and if you look really close at it with the sunlight shining directly into it you can see a bunch of glimmers suspended in the oil. I also tested compression on all cylinders. Number 1 through number 5 all had ~ 125lbs (wrong unit of measure I am sure, ignore that), but cylinder 6 had 0lbs. Also the spark plug from cylinder 6 looked black and oily. The other spark plugs ranged from the perfect camel brown to sort of white/ lean mixture looking. Finally, I decided to remove the valve cover to get a look at the lifters and push rods. As soon as I removed the first valve cover bolt, coolant started pouring out. Several more of the VC bolts had fluid behind them as well. I didn't think the VC bolts went into the water jacket?
All of this to ask for your opinions. What do you all think might be wrong, and where should I go from here? I was thinking to remove the oil pan and take a look at the crankshaft and bearings and the piston skirts. Anything else I need to do or look into?
Get a fine gasket scraper and pound it gently into the edge.  A drywall putty knife will work too if it is stiff enough, many aren't.
Or you can put a block of wood against the pan and go at it with a sledge (turn the block sideways to spread the load) but that's a bit more destructive.
it`s pretty obvious whats wrong with it, hope the damage is fixable...
