omega_rugal Posted March 10, 2017 Share Posted March 10, 2017 never mind, guess what was it? a solenoid... :fs1: Link to comment Share on other sites More sharing options...
cruiser54 Posted March 10, 2017 Share Posted March 10, 2017 Good question, I will check that as soon as I have a chance and report back. How long should I crank the motor to get a voltage reading? should the reading be steady? 5 seconds/ Link to comment Share on other sites More sharing options...
big66440 Posted March 10, 2017 Share Posted March 10, 2017 never mind, guess what was it? a solenoid... :fs1: Which solenoid is that? Link to comment Share on other sites More sharing options...
omega_rugal Posted March 11, 2017 Share Posted March 11, 2017 never mind, guess what was it? a solenoid... :fs1: Which solenoid is that? either the B+ latch or the Fuel Pump wasn`t closing properly, to be sure changed both, it`s working so far... Link to comment Share on other sites More sharing options...
cruiser54 Posted March 11, 2017 Share Posted March 11, 2017 never mind, guess what was it? a solenoid... :fs1: Which solenoid is that? either the B+ latch or the Fuel Pump wasn`t closing properly, to be sure changed both, it`s working so far... Coulda found that out by moving each of the relays over one spot. Link to comment Share on other sites More sharing options...
big66440 Posted March 16, 2017 Share Posted March 16, 2017 My CPS was soldered directly to the ECM, I guess there was a TSB to bypass the "harness" so the ECM gets a stronger signal according to some bits of info I found?. I placed an order for a new Mopar CPS ( Part Number T0739789 ) and have 2 Delphi weatherpack connectors to do it right. I'm planning on modifying the new sensor to advance the timing and drill the holes to get it closer to the flex plate to cover all the bases. Link to comment Share on other sites More sharing options...
Ωhm Posted March 16, 2017 Share Posted March 16, 2017 I'm planning on modifying the new sensor to advance the timing and drill the holes to get it closer to the flex plate to cover all the bases. Won't this affect INJ timing also? I understand the 'closer' side of this, but moving the pickup, changes TDC. Link to comment Share on other sites More sharing options...
cruiser54 Posted March 16, 2017 Share Posted March 16, 2017 I'm planning on modifying the new sensor to advance the timing and drill the holes to get it closer to the flex plate to cover all the bases. Won't this affect INJ timing also? I understand the 'closer' side of this, but moving the pickup, changes TDC. No. Injector timing is controlled by the sync generator in the distributor. Link to comment Share on other sites More sharing options...
cruiser54 Posted March 16, 2017 Share Posted March 16, 2017 My CPS was soldered directly to the ECM, I guess there was a TSB to bypass the "harness" so the ECM gets a stronger signal according to some bits of info I found?. I placed an order for a new Mopar CPS ( Part Number T0739789 ) and have 2 Delphi weatherpack connectors to do it right. I'm planning on modifying the new sensor to advance the timing and drill the holes to get it closer to the flex plate to cover all the bases. If I remember correctly, the bulletin replaced the CPS with one that had a slotted hole in it for the upper bolt. Still had a plug, but a harness was wired through a hole drilled in the firewall and the harness was pinned directly into the eCU. I could find it if you want. Longer crank times can sometimes be caused by a bad sync generator. There is a test procedure for it somewhere. since I have the factory tester I always rely on that to tell me if it is good. Link to comment Share on other sites More sharing options...
Gene Posted March 16, 2017 Share Posted March 16, 2017 Still had a plug, but a harness was wired through a hole drilled in the firewall and the harness was pinned directly into the eCU. I could find it if you want. Hi cruiser, I would be very interested in seeing this! Thanks Gene Link to comment Share on other sites More sharing options...
Ωhm Posted March 16, 2017 Share Posted March 16, 2017 I'm planning on modifying the new sensor to advance the timing and drill the holes to get it closer to the flex plate to cover all the bases. Won't this affect INJ timing also? I understand the 'closer' side of this, but moving the pickup, changes TDC. No. Injector timing is controlled by the sync generator in the distributor. Sync signal determines INJ sequence. INJ timing uses teeth count on the flywheel. Not here to start a pissing contest, just a understanding. Maybe a new topic, don't want to hijack thread. Link to comment Share on other sites More sharing options...
cruiser54 Posted March 16, 2017 Share Posted March 16, 2017 I'm planning on modifying the new sensor to advance the timing and drill the holes to get it closer to the flex plate to cover all the bases. Won't this affect INJ timing also? I understand the 'closer' side of this, but moving the pickup, changes TDC. No. Injector timing is controlled by the sync generator in the distributor. Sync signal determines INJ sequence. INJ timing uses teeth count on the flywheel. Not here to start a pissing contest, just a understanding. Maybe a new topic, don't want to hijack thread. Hmmm. the ECU has a default for determining sequence. I believe that's why a bad sync generator's only symptom is longer crank times. And, the factory made their own high altitude CPS which had the sensor portion moved on the mount. See here: http://cruiser54.com/?p=127 Link to comment Share on other sites More sharing options...
cruiser54 Posted March 16, 2017 Share Posted March 16, 2017 Still had a plug, but a harness was wired through a hole drilled in the firewall and the harness was pinned directly into the eCU. I could find it if you want. Hi cruiser, I would be very interested in seeing this! Thanks Gene TSB 18-51-88 Link to comment Share on other sites More sharing options...
