The 2.5L in my 89 MJ is getting tired. (45/80 leakdown no1 cyl. being worse ).
What model and what years can I look for in the Jeep line up to replace this motor ?
Understanding I will need to change the TBI intake manifold  If I find a MPI engine.
What other things would I need to switch over from the TBI  engine ?
General price range for an engine ?
Thanks.
the block can be swapped with any MJ/XJ/wrangler 2.5L 84-2000 something.  can't remember the actual cutoff.  car-part.com can help with prices and searches.  you might need to search for various years since the search engine only knows part numbers and I'm sure that changed over the years.
The Jeep 2.5L was also used in some years of the Dakota pick-up. I don't know which years, exactly, nor do I know if there were any differences in mounts or accessories.
Not sure where you are located but there is a 86 Cherokee in the junkyard by me, complete 2.5l, manual trans and 4x4. Its at the blue island lkq in Illinois, zip code is 60406
If you are anywhere near southwestern PA, I have a spare 2.5 sitting in storage.  You can have it for free if you can get it....
Jeff
Thanks for all the info. Here in Michigan it's to cold to spend much time in the garage so this  change-out may wait for warmer weather.
The MJ is not a daily driver so no hurry. Did find a 2.5 with 155K miles, removed from a Wrangler $400 only 75 miles away
Keep in mind that 155k miles on a 2.5L equates to more miles on a 4.0L. The 2.5L typically came with 4.10 gears (except the early 4-speed manuals -- and they didn't have overdrive). Using the more popular automatic 4.0L for comparison, those had 3.55 gears so the engine turned fewer revolutions for every mile driven. In terms of engine wear, that's equivalent to 179,000 miles.
Still not "worn out." I have a 2.5L MJ that has 209,000 miles on it and didn't burn oil the last time I drove it. But I wouldn't just drop in an engine with 155k or 179k miles, without going through it and at least replacing the bearings. Better would be a complete rebuild.
