What is this part called?
I'm leaking brake fluid out of the top of a gold piece where all my brake lines connect. I think its called a proportion valve? Anyways its like a sensor for the light in the cab to come on when its low. My light doesn't come and so I would assume that its no good. Its kinda yellowish in color and is directly on top with a connection going to it
I believe it's called a distribution block on our trucks, if that's what you are talking about it's not available from the aftermarket. You're best bet would be to post a wanted ad in the classifieds or ebay, or you can pull one off of an XJ but you may have to modify it.
I just need the sensor that goes into the top of it
It's not a sensor, it's a plunger switch. You can use one out of any Cherokee or Grand Cherokee. The switch is the same for all of them, although the valve/block bodies are different.
Thanks eagle! Do you know if I can get one from a auto zone or advanced? Also if the plunger failed would that cause the brake light to not come on the dash when the fluid is low
The switch on the combination valve (or proportioning valve, or distribution block) is a pressure differential switch.  It does not tell you the brake fluid in the master cylinder is "low".  It does tell you if a leak has developed somewhere downstream of the valve and you are now operating on either the front or rear brakes ONLY, depending on where the leak/failure is in the system.  Also, it may be activated if the master cylinder is EMPTY and only one circuit (front or rear) has enough fluid remaining to operate.
Also, not sure how you are determining the pressure differential switch is bad.  The brake light on the dash could be out.  It is the same light that should come on when the parking brake is applied, so that is one way to test it.  Although if it does not come on when the parking brake is applied that doesn't automatically mean the bulb is bad, it could be a bad switch on the parking brake or a fault somewhere else in the circuit.
Is that what your switch looks like? Cause I might have one laying around.
Yes mine looks just like that one except its all gold and not silver
No, you're referring to the entire distribution block (or proportioning valve, in the case of the XJ). The switch is just the small, plastic thing that screws into the top. If that's what's leaking on yours, that's all you need, and the XJ part is the same as the MJ part. (And I'm 98.37% certain it's also the same on the ZJ Grand Cherokee.)
However:
Take a look at the two cutaway photos I posted. It occurs to me that you may, in fact, need the entire valve assembly. The plunger switch itself should be isolated from brake fluid by the O-rings on the shuttle valve (that horizontal thingie that slides back and forth in the top of the valve body). If you've got brake fluid coming out the switch body, that's an indication that at least one of the internal O-rings has failed. I don't think the switch is intended to have contact with brake fluid.
However:
Entirely correct.
Brake fluid is coming from where the plunger screws into the block, do I need entire block or just that plunger then? Or an o ring?
The plunger doesn't screw into the valve body, the switch body screws into the valve body. The plunger is in the switch. What I was trying to say is that brake fluid should not get to the plunger or the switch body. You need at least an O-ring, but who knows which one, what size it is, or what type of rubber it's made of? It's probably easier in the long run to replace the entire assembly -- the distribution block. (Or "valve/brake" in Hornbrod's photo)
Keep in mind that, although the actual plastic switch is the same for the XJ, MJ, and ZJ, the overall distribution block/proportioning valve (the body) is not -- as can be seen in the two cut-away photos I posted above. The MJ has the proportioning function handled by the height-sensing proportioning valve mounted to the frame above the rear axle, and there are two lines from the distribution block to the rear. For the XJ and ZJ, the front valve block handles proportioning and there is only one brake line from the proportioning valve to the rear axle.
That means you will have to find one from an MJ to accomplish a drop-in, OEM replacement. You can use a proportioning valve from an XJ or ZJ, but you'll have to abandon the second line and the height-sensing proportioning valve. And, since ZJs has disc brakes in the rear, I believe (but I'm not certain) that the proportioning valve for the ZJ was calibrated differently than that for the XJ. If you're going to go that route, I don't know which would work better in an MJ.
I doubt you will find the MJ distribution block easily at the yard. If you can't find one, I'd unscrew the brass valve stem and bring it to your local Mom and Pop auto parts store that's been there about 100 years (most every town has one), rummage through their o-ring assortment box and replace every o-ring on the stem. I'm betting you will probably find one or two of them torn or disintegrated. Also remove the plastic switch and make sure the body isn't cracked. Put it all back together and you'll probably be good to go.
I will try this thank you! I went to a junkyard and grabbed a xj one just in case the o ring method doesn't work. I know I may have to do some modifying but I think I'll be able to figure it out
