Where to buy Front Underpanel?
What under panel? There was a factory skid plate that "protected" the steering components (it's pretty thin) and that could also keep some stuff from splashing up into the engine bay, but I think that's about it. You might luck out and spot one under the front of an XJ.
Mm. I actually know very little about the '97+ XJ's. It's probably obvious sometimes.
Almost all of them were ripped off at some point and never put back on. Mostly because the early model ones at least get soggy and torn up and are a real PITA to deal with if you have to do anything on the bottom of the engine. Apparently the 97+ ones are made out of a different material, but I don't know if I've ever seen one of those.
