mik666 Posted January 2, 2017 Posted January 2, 2017 Hey all best wishes for the new year! I have encountered a problem that i hope the collective wisdom of the forum can help me with. My 87 2wd auto occasionally won't start as of late. All the instruments etc in the cab have power, there is just no cranking of the motor -regardless if its park or if i switch to neutral. I have replaced all the power cables, and done the ground refreshing etc along with replacing the ignition switch that's down in the column (my turn signal relay went out so i replaced them both at the same time) . If i wait for a bit it always starts up again, but i'm fearful it will take a dump on me in some remote location and won't start. Should i be looking a some replay perhaps ? or other suggestions ? thx as always! Mike
cruiser54 Posted January 2, 2017 Posted January 2, 2017 when you turn the key to Start and nothing happens, what is your voltmeter indicating?
mik666 Posted January 2, 2017 Author Posted January 2, 2017 Hi Cruiser i don't have accurate numbers, but there is a large drop from 12.5V on my dash board volt reader even if the truck starts - the non starts occurs so infrequently i haven't checked that out yet as it always catches me by surprise and like i said it seems to start 2-3 mins after the non start condition (at least to date it has) m
cruiser54 Posted January 3, 2017 Posted January 3, 2017 Make a point to watch it every time you go to start your truck.
omega_rugal Posted January 3, 2017 Posted January 3, 2017 sinc ethe rpoblem come and goes by itself, can be as bad as a failing starter and/or solenoid or as simple as a ignition switch makign fun of you.... you can start there...
cruiser54 Posted January 3, 2017 Posted January 3, 2017 sinc ethe rpoblem come and goes by itself, can be as bad as a failing starter and/or solenoid or as simple as a ignition switch makign fun of you.... you can start there... Start where?
gogmorgo Posted January 3, 2017 Posted January 3, 2017 Try switching quickly back and forth from park to neutral next time it happens. Sounds like a neutral safety switch issue to me. Mine started out infrequent and usually would start if I stuck it in neutral but sometimes wouldn't, getting worse and worse until I was having to short the solenoid to get it to start two out of three times. It wouldn't hurt to clean out the NSS anyhow. If it's never been done it could probably use it anyhow. http://bc4x4.com/tech/2010/jeep-neutral-safety-switch-nss/. I ran a bead of silicon around mine before putting it back together to try to keep grime out a bit longer. Could also be the rod between the ignition cylinder and the switch is out of adjustment and sometimes doesn't quite make contact. But my money's on the NSS.
omega_rugal Posted January 3, 2017 Posted January 3, 2017 Start where? ignition switch <-> Starter/Solenoid...
cruiser54 Posted January 3, 2017 Posted January 3, 2017 Start where? ignition switch <-> Starter/Solenoid... And do what with them?
omega_rugal Posted January 3, 2017 Posted January 3, 2017 And do what with them? well, i don`t know, drop the starter, wire it to a good battery and make sure it turns as it should, he says the ignition switch is new but is it really working? mine has to be turned and pushed really hard sometimes to make good contact, he has an auto tranny, is the neutral switch really working? the problems seems very straight forward to me...
cruiser54 Posted January 3, 2017 Posted January 3, 2017 And do what with them? well, i don`t know, drop the starter, wire it to a good battery and make sure it turns as it should, he says the ignition switch is new but is it really working? mine has to be turned and pushed really hard sometimes to make good contact, he has an auto tranny, is the neutral switch really working? the problems seems very straight forward to me... But, it's intermittent. That's why he needs to narrow it down by watching the voltmeter......... If he pulls the starter and it spins, what does that tell him? It's spinning now, but wait, it does that most of the time. The test above will also help pinpoint a bad NSS.
HOrnbrod Posted January 3, 2017 Posted January 3, 2017 I had this problem - it was intermittent. Turned out the brushes in the starter were toast. Is your starter motor the original?
mik666 Posted January 3, 2017 Author Posted January 3, 2017 OK thx guys - i'll watch the volts and play around - going between neutral and park didn't seem to make any difference - problem is its done it once in the last 3 weeks - prior to changing out the ignition switch it was doing it about once a week so i thought i had nailed it down but apparently not, i do believe the starter is original - i'm also trying to remember if i hear the fuel pump spinning up when there is a non start but can't recall - i'll pay more attention and start compiling a list addressing the suggestions the next time it occurs
64 Cheyenne Posted January 3, 2017 Posted January 3, 2017 Without being there and doing a proper diagnosis, I'd have to bet on the starter.
mik666 Posted January 10, 2017 Author Posted January 10, 2017 hey Gang So i replaced the starter, not sure if that was it or not but i had a $40 discount from Napa so figured why not, ended costing me about $33 - the new starter sounds different than the old one for what ever that worth. The non start hasn't occurred, so maybe that it - but i'm going to pull the NSS and clean it up - can you guys tell me will the one on my jeep (2wd) be similar to the one described in this link http://bc4x4.com/tec...ety-switch-nss/. ? thanks as always! mike
HOrnbrod Posted January 10, 2017 Posted January 10, 2017 New fresh starter motors always sound different since the bearings and solenoid linkage are well, new and tight. They also usually crank a lot faster than the one it replaced because the mains connections are cleaner with less resistance. And all Jeep AW4 NSS's are the same.
mik666 Posted January 14, 2017 Author Posted January 14, 2017 great cleaned out the NSS, took only about 45 m - so easy was awful gunked up - hopefully the no start is a past issue! thx all!
GrayWolf Posted January 23, 2017 Posted January 23, 2017 Had the same problem last year. Went to an old guy, even older than me, who has had an auto electric business since Thomas Edison. First thing he asked me was where the starter is located. I looked at him, wondering what he was up to, and told him. He then asked if I knew what was right above it, and I told him it was the oil filter. He then finally explained that when people still had their starters rebuilt, he got a lot of 4.0 starters in because they ended up with oil inside the housing that eventually shorts the armature. Let it sit for awhile, the oil drains down and often it will start until next time. I put a new starter in, and it's been great ever since. Took the old one apart before I took it back for core, and sure enough it had about a tablespoon of oil in it and was generally a mess.
