Skyryder55 Posted November 15, 2016 Share Posted November 15, 2016 Good morning folks. I'm about to be the new owner of a 1988 Comanche. I've been wanting one for years and one has popped up on local classifieds. It's a 2wd 5 speed with the 6 cylinder. Body seems to be in great shape other than rockers, cab corner and door panel. Interior is mint. 157K kms. I'm looking to do a 4wd swap right away with it. Looking for some insight on best route to go for components. Year and model. I want to stay as a 5 speed. This beast will be replacing my 1997 Suzuki sidekick that is getting pretty tired. Only about 150K kms on her but they have been rough off-road kms. Lol. I also plan to swap a vw tdi into the jeep down the road Link to comment Share on other sites More sharing options...
Skyryder55 Posted November 15, 2016 Author Share Posted November 15, 2016 As a side note, I'm fully capable of handling the work of doing the swap. And custom fabrication is not something I shy away from. Link to comment Share on other sites More sharing options...
ComancheKid45 Posted November 15, 2016 Share Posted November 15, 2016 Welcome. For your 4wd swap needs the consensus is to find a wrecked XJ Cherokee and utilize as many components from it as you can. Everything from the B pillars forward are identical. Not sure though if you can keep your 2wd transmission... Link to comment Share on other sites More sharing options...
Skyryder55 Posted November 16, 2016 Author Share Posted November 16, 2016 So what year range can I look at? I know there are amazingly some electrical differences. And if I need to drop in a new engine, (this one has a tick) what years would be a direct swap? Link to comment Share on other sites More sharing options...
HOrnbrod Posted November 16, 2016 Share Posted November 16, 2016 Good places to start reading: http://comancheclub.com/topic/48710-diy-projects-writeups-master-search-index/ http://comancheclub.com/topic/48463-cruisers-mostly-renix-tips/ Link to comment Share on other sites More sharing options...
Pete M Posted November 16, 2016 Share Posted November 16, 2016 they all have a tick. nothing to worry about. might just be a loose rocker. welcome to the addiction! :waving: Link to comment Share on other sites More sharing options...
cruiser54 Posted November 16, 2016 Share Posted November 16, 2016 Welcome. 87 to 90 XJ donors will be the simplest. Link to comment Share on other sites More sharing options...
Skyryder55 Posted November 16, 2016 Author Share Posted November 16, 2016 Great! Thank you for the info. At least now I'll have a good baseline to go from and what to look for Link to comment Share on other sites More sharing options...
grinch Posted November 16, 2016 Share Posted November 16, 2016 Welcome! Get ready to Just Empty Every Pocket :laughin: Link to comment Share on other sites More sharing options...
Skyryder55 Posted November 16, 2016 Author Share Posted November 16, 2016 I already have a well equipped Suzuki sidekick. So I've already got rubber and a winch. I am capable and have the facilities to do whatever fabrication I choose to do. I have a vw corrado that I was swapping a tdi into. This project will replace the corrado. I'll be stripping it down and selling it off. Once Comanche 4wd swap is done I'll sell the sidekick. Too any horses in the stable. Lol. Link to comment Share on other sites More sharing options...
Skyryder55 Posted November 26, 2016 Author Share Posted November 26, 2016 First update. The purchase is official. Went and saw it today. It was easier than planned, but I believe very workable. Interior is mint. Box interior is very solid. Rust on arches and corners of box. Cab floors and rockers are shot. Engine idles rough but once it's warmed up smothes out. Runs really nice abo e idle. So now the sourcing of parts will begin. Any recommendations for good sources for replacement rockers and floors. Not much will be happening to this beast over the winter. But it will be good to start amassing parts. Link to comment Share on other sites More sharing options...
Skyryder55 Posted December 16, 2016 Author Share Posted December 16, 2016 So need some advice. I've got an option to buy a 98 Cherokee. Only 160K kms on it. Body is trashed. Was a rollover. Has a 5 speed. Engine is pulled. Is this a good donor for my 4wd conversion? Link to comment Share on other sites More sharing options...
johnj92131 Posted December 17, 2016 Share Posted December 17, 2016 Just from the fact that you eventually want to do a TDI conversion, the 98 5 speed will save you buying an AX15 transmission later on. If you get an 87-90 Cherokee, you most likely will not get an AX15 transmission. The 98 clutch is external and a 87-90 clutch will be internal. So that is a plus for the 98. I would check the DIY section to see what, if any sensor are different. Thinking speedometer is different (electric vs mechanical). Don't know if anything else is different. Link to comment Share on other sites More sharing options...
Pete M Posted December 17, 2016 Share Posted December 17, 2016 techj questions should really go in the tech forum. :thumbsup: Link to comment Share on other sites More sharing options...
