BradH71 Posted October 3, 2016 Share Posted October 3, 2016 I picked up an '88 2wd a few weeks ago. It needed a bad tune-up, but I got it home under its own power. I got it running good, it shifts good, it stops good. I thought I got a great deal on it seeing as I paid $250 and a case of beer, but when I pulled the bench and flooring I quickly realized what I had got myself into...It's pretty well rusted. What I need help on is deciding a) Is it worth fixing? and b) How do I go about fixing it if it is worth it? I'd love to 4x4 swap this truck as I see a lot of potential, but I can't see the sense in putting my time and money into it if it's too far gone. Thanks in advanced. Link to comment Share on other sites More sharing options...
Pete M Posted October 4, 2016 Share Posted October 4, 2016 I've owned worse. :D how are your welding skills? Link to comment Share on other sites More sharing options...
omega_rugal Posted October 4, 2016 Share Posted October 4, 2016 can be fixed, don`t worry... Link to comment Share on other sites More sharing options...
pitbull4x4 Posted October 6, 2016 Share Posted October 6, 2016 Looks about like mine when I got it. But new floor pans and a friend who can weld I now have a solid floor. So yes can be fixed and if you do it enjoy working on it Link to comment Share on other sites More sharing options...
mikekaz1 Posted October 7, 2016 Share Posted October 7, 2016 ugly, but not bad. pretty typical really. Link to comment Share on other sites More sharing options...
1989 comanche mj Posted October 8, 2016 Share Posted October 8, 2016 Mine was worse also, and I had to bend up some metal because the aftermarket replacements didn't extend far enough. The pans are difficult on these, you can't get the correct ones, so you have to make due with cherokee ones. Link to comment Share on other sites More sharing options...
hassyfoto Posted October 9, 2016 Share Posted October 9, 2016 As everyone has already stated, typical rust, as rust goes the floor is one of the easiest areas to repair. Inner and Outer rocker panels are a little more involved, while frame/uni-body rails are much harder & sometimes not really repairable except by a professional ( multiple layers of metal and specialized welding ). The nice thing about repairing a floor, it is not seen and only needs to be structurally sound and not cosmetically pretty! Use can buy floor pans to start and add metal to the transmission hump, where the floor pans stop or create your own patch panels from scratch, either way will work. Link to comment Share on other sites More sharing options...
