kansashogan Posted September 27, 2016 Share Posted September 27, 2016 Does a plugin pigtail exist or do I need to splice one in? Link to comment Share on other sites More sharing options...
tugalo Posted September 27, 2016 Share Posted September 27, 2016 Splice it in yourself. There are several good articles in this forum and one of them tells you which wire colors to match an after market harness to the original wiring. i recommend either soldering or using Raytheon environmental splices instead of the normal butt splices. Easy job. Link to comment Share on other sites More sharing options...
kansashogan Posted September 28, 2016 Author Share Posted September 28, 2016 OK thanks Link to comment Share on other sites More sharing options...
mikekaz1 Posted October 1, 2016 Share Posted October 1, 2016 Its pretty easy to remove the entire rear harness. I found this easier then trying to splice installed under the bed. Also lets you better inspect all the wiring for cuts and faults. Link to comment Share on other sites More sharing options...
jake_89/87_comaanche Posted May 31, 2017 Share Posted May 31, 2017 if you can find a spare plug (both male and female ends) you can make your own plug in connector. Link to comment Share on other sites More sharing options...
Eagle Posted May 31, 2017 Share Posted May 31, 2017 if you can find a spare plug (both male and female ends) you can make your own plug in connector. This is the best way to go, IMHO. Also, are you looking for a flat, 4-wire connector, or a round, 7-wire connector? Link to comment Share on other sites More sharing options...
schardein Posted May 31, 2017 Share Posted May 31, 2017 if you can find a spare plug (both male and female ends) you can make your own plug in connector. This is the best way to go, IMHO. Also, are you looking for a flat, 4-wire connector, or a round, 7-wire connector? This is the route I went, and it got me to wondering if the connector in question is used on any other vehicles. Perhaps Dakotas of the same year? I haven't checked yet, but it would be nice if we could confirm a more easily available source than junked Comanches. I've got pictures of the male/female connectors somewhere on my computer... Link to comment Share on other sites More sharing options...
johnj92131 Posted June 1, 2017 Share Posted June 1, 2017 Next time I do the trailer harness thing, I will get a full 7 wire set up with a brake controller. I have an adapter plug that goes from 7 wire to 4 wire in the glove box. But it does me no good because I only have a 4 wire connector on the Comanche. So my advice is to do a 7 wire and a 4 wire connection at the same time. Yes a bit more expensive. But I like the idea of electric brakes on anything I tow. Last summer, I towed a 1986 Comanche on a U haul dolly from Victoria, B.C to Northern Michangan with my 1991 Comanche. About 2400 miles from sea level to over 8000 feet of the Rocky Mountains. After that, you appreciate good brakes. Link to comment Share on other sites More sharing options...
Crash Posted June 1, 2017 Share Posted June 1, 2017 My MJ has the GM weatherpack style plug, I'm considering finding another piece of harness or buying pigtails to 'tee' into the circuit for trailer wiring. Would make removing or changing it a cleaner install. Link to comment Share on other sites More sharing options...
jpdriver1 Posted June 3, 2017 Share Posted June 3, 2017 Next time I do the trailer harness thing, I will get a full 7 wire set up with a brake controller. I have an adapter plug that goes from 7 wire to 4 wire in the glove box. But it does me no good because I only have a 4 wire connector on the Comanche. So my advice is to do a 7 wire and a 4 wire connection at the same time. Yes a bit more expensive. But I like the idea of electric brakes on anything I tow. Last summer, I towed a 1986 Comanche on a U haul dolly from Victoria, B.C to Northern Michangan with my 1991 Comanche. About 2400 miles from sea level to over 8000 feet of the Rocky Mountains. After that, you appreciate good brakes. I went this route on the wife's durango -- picked up a unit at the store that had both wired together -- only need to plug into the taillight set up Link to comment Share on other sites More sharing options...
mikekaz1 Posted June 5, 2017 Share Posted June 5, 2017 I love the 5 pin/7blade combo units. great investment to not have to deal with adapters Link to comment Share on other sites More sharing options...
