my project ive been planning for the last year and just started doing
here is the bds xj long arm crossmember I'm using nice piece all 1/4inch
and the lower arms i just got done making
finished pic of upper control arm and track bar bracket
and the copy of jcr 1 ton set up I'm doing tie rod here drag link later
rd84, you need a front axle, front driveshaft, rear driveshaft specific to your wheel base/trans/tcase/axle combo, 4wd transmission, transfer case, 4wd transmission crossmember, and 4wd linkage. if your front axle is a vacuum diconnect modle, you also need the vacuum linkage. beyond that, you might want a center consol to accomediate the t-case shifter, and anything else depends on what you want to do at the same time (upgrade steering, control arms, lift, etc...
i think that's about it. since the 2wd's use a solid axle and the same suspension set up, it's pretty simple as far as conversions go.
Nice. I'm doing an almost identical project. .250 wall tubing? Do you need to/Are you going to add bracing to the unibody and crossmember connection? Good luck.
yes .250 wall and probly will reinforce unibody
did you order the crossmember reght from BDS seperate. That's a nice piee to start out with and would save me alot of time from fabing my own. How much was it if you don't mine me asking?
no i bought it locally a place called rbr offroad he sells stuff at wholesale so it was cheaper than buying it from bds it was 290 from rbr they have a web site its www.rbroffroad.com
  • 9 months later...
not to much more to add ran out of money but just getting back to it. found dana 44 out of comanche rebuilding that now, will add current pics soon.
