mrmel2you Posted May 25, 2016 Posted May 25, 2016 I pulled the driver side door panel off, to replace the mirror, and found this laying in the bottom of the door. I have no idea what it is or what/where it was attached to. Anyone have any ideas? http://i.imgur.com/n2vBZLO.jpg http://i.imgur.com/V1pEF4w.jpg
fiatslug87 Posted May 25, 2016 Posted May 25, 2016 That's the door check, actually it's a broken door check. It bolts to the door and the arm that's missing attaches to the door frame using a bracket and roll pin. http://www.amazon.com/Dorman-924-148-Door-Check/dp/B00GHT6ZWU/ref=au_as_r?_encoding=UTF8&Make=Jeep%7C42&Model=Cherokee%7C347&Year=1990%7C1990&ie=UTF8&n=15684181&newVehicle=1&s=automotive&vehicleId=1&vehicleType=automotive http://www.amazon.com/Cherokee-Comanche-check-bracket-MOPAR/dp/B00LFW2Y10
mrmel2you Posted May 25, 2016 Author Posted May 25, 2016 Thank you "MJ Junkie", That's what was causing all the rattling I have been hearing when I close the door, LOL :) No telling how long it has been broken, need to get this fixed as well. Thank you for the links also, pinpointed it :) Papa Mel, Happy Trails everyone :)
88mjblue Posted June 24, 2016 Posted June 24, 2016 I've seen this many times, it is very common and is a fault of the mj/xj design, or the strength of the metal as a whole/inadequate bracing/support. My 88 mj, 90 xj, 95 xj, and 88 xj all have this problem on the driver's side door as well as the passenger side. Two of them had the door check completely ripped through the door metal - nut still attached - (similar to yours judging by your picture) and the metal on the door where it bolts up to was mangled so a new one would not bolt up. I removed them to solve the rattling like you had, and I'm just careful when opening the door so it doesn't swing open too far which would put stress the door hinges directly (which the door check is meant to prevent). The other two xj's have the door check hanging on by one bolt, but don't work properly: not ratcheting and can't hold the weight of the door, so it swings free (but stops from stressing hinge fortunately). I guess a solution would be to fab a plate of some sort (or maybe even a wide washer might work) to reinforce that area where the check mounts up to so you could properly mount up a new one. At this point, I have just removed mine, and now the door operates smoothly, with no rattling when driving/closing, but it does not hold it's position - so it's like a yj/tj door... Let me know if you find a solution and can mount up a new one that will hold for years to come.
velco Posted June 24, 2016 Posted June 24, 2016 Thanks for the info...I was wondering what was growling down there when I used the door. Tried lubing the slider to no avail. Going to have to get inside the door and lube the spring before it explodes.
GirsMJ86 Posted June 25, 2016 Posted June 25, 2016 Just curious since I've never heard these called this before, but I'm taking this is what stops the door from opening too far? If so, since these tend to break, could a "solution" be to add something like the Wranglers had/have? Just a strap that hooks from body to door that prevents it from swinging open? Of course the door still wouldn't hold it's position, but that's not something I'd be worried about. Just wouldn't want it to swing too wide.
cruiser54 Posted June 25, 2016 Posted June 25, 2016 They fail internally just from use and no lubrication/maintenance. Once they break, they hammer the hell out of the door metal. I cut the metal out of old doors and make bolt in reinforcement plates.
