Help with ATV problems
Jackrabbit41
So I have a 2005 Yamaha 350 raptor. I had it running one day and then I turned it off. Then about 10 minutes later I tried to start it again and it cranks but doesn't fire over. Pulled the plug and I have no spark. I'll I've done now is put in a new plug, still no spark, and check fuses. I don't really know much about what to check next. Just looking for some help. I checked some of the connections and everything looks good and not corroded. Also this quad is leaking some kind of oil. It's not engine oil becuase every time I check the oil it's in the same spot. I don't know what else it could be because it uses a wet clutch so isn't the motor oil the only oil in there? It ain't brake fluid either. It's coming from underneath the thing behind the foot shift lever. Thanks y'all hopefully you guys know about atvs too!
I've had the stator go bad in my 00 Wolverine 350. It started and ran fine but did not charge the battery.
My bet would be on the coil if all the electrical connections check out good.
I'm just assuming his quad thingy functions like my two stroke dirt bike where the stator provides the electricity for the spark.
I've seen other guys talk about the stator. What is it and where is it?
Should be on the other side of your clutch. Underneath the cover. On my dirt bike it had 3-4 phillip screws holding it in and then pull it off the crank.
