Leaking coolant
Get them in brass if possible so they don't rot out again. Usually when one goes the others follow.
Should I get the later model plugs? They come in copper...but not sure if they are the correct size
I'd use them if the size was right.
Glad you found the culprit!
There is no coolant relevant to either of the manifolds.
This is false for the 2.5 TBI power plant. Coolant does flow through the intake manifold by way of the upper heater hose. Granted the loose intake manifold bolt wouldn't cause a leak.
Sorry, didn't read close enough and have next to zero 2.5 experience. Glad I learned something today. ;)
So I bought both...dorman 555-014 steel and the 565-014 copper for the later model 2.5s....
Removing the old plugs were a bit challenging being my first time but popped them out and installed all 4 in about 10mins....
I decided to do the copper first and they fit perfect!
Install pics...
