cruiser54 Posted April 1, 2016 Share Posted April 1, 2016 Not simple, but I had 2 of them around. Link to comment Share on other sites More sharing options...
Incommando Posted April 1, 2016 Share Posted April 1, 2016 Link to comment Share on other sites More sharing options...
benjy_26 Posted April 1, 2016 Share Posted April 1, 2016 Link to comment Share on other sites More sharing options...
johnj92131 Posted April 1, 2016 Share Posted April 1, 2016 Cruiser, I like what you did there! Looks like you had to cut and splice the 2 WJ/ZJ hitches together. I had toyed with picking up a Grand Cherokee hitch just for the square tubing and using Krustyballers hitch plates to bolt it on to the Comanche. Link to comment Share on other sites More sharing options...
cruiser54 Posted April 1, 2016 Author Share Posted April 1, 2016 93 Grand cherokee aftermarket hitch. The GC's rear bumper brackets supply 2 of the 3 nuts for a nut strip, with some cutting involved. One of the 2 holes is off a bit so I had to drill a new hole on each side. The GC's side brackets where they bolt up to the frame are the same as xJs if that helps. I needed to extend each side as the MJ's frame rails are further apart. Used 2.5 heavy square tubing (2.5" ID) to sleeve it together. Link to comment Share on other sites More sharing options...
mikekaz1 Posted April 2, 2016 Share Posted April 2, 2016 I just finished this today. $60 for the plates from Brandon, $20 for the 2.5" tube, $20 for the receiver and $20 for powder coat. Link to comment Share on other sites More sharing options...
cruiser54 Posted April 2, 2016 Author Share Posted April 2, 2016 On 4/2/2016 at 2:03 AM, mikekaz1 said: I just finished this today. $60 for the plates from Brandon, $20 for the 2.5" tube, $20 for the receiver and $20 for powder coat. Nice!!! Link to comment Share on other sites More sharing options...
mikekaz1 Posted April 2, 2016 Share Posted April 2, 2016 Link to comment Share on other sites More sharing options...
benjy_26 Posted April 2, 2016 Share Posted April 2, 2016 On 4/1/2016 at 8:23 PM, cruiser54 said: 93 Grand cherokee aftermarket hitch. The GC's rear bumper brackets supply 2 of the 3 nuts for a nut strip, with some cutting involved. One of the 2 holes is off a bit so I had to drill a new hole on each side. The GC's side brackets where they bolt up to the frame are the same as xJs if that helps. I needed to extend each side as the MJ's frame rails are further apart. Used 2.5 heavy square tubing (2.5" ID) to sleeve it together. Cool deal! Link to comment Share on other sites More sharing options...
fiatslug87 Posted April 2, 2016 Share Posted April 2, 2016 On 4/2/2016 at 2:03 AM, mikekaz1 said: ...and $20 for powder coat. That's a great deal! Around here they want $100 to coat one wheel, I need to find another place. Link to comment Share on other sites More sharing options...
mikekaz1 Posted April 2, 2016 Share Posted April 2, 2016 On 4/2/2016 at 3:18 PM, fiatslug87 said: On 4/2/2016 at 2:03 AM, mikekaz1 said: ...and $20 for powder coat.That's a great deal! Around here they want $100 to coat one wheel, I need to find another place. A good friend of mine has a body shop. So as long as its nothing intricate or difficult, he just charges me supply cost. Link to comment Share on other sites More sharing options...
Eagle Posted April 2, 2016 Share Posted April 2, 2016 On 4/1/2016 at 8:23 PM, cruiser54 said: 93 Grand cherokee aftermarket hitch. The GC's rear bumper brackets supply 2 of the 3 nuts for a nut strip, with some cutting involved. One of the 2 holes is off a bit so I had to drill a new hole on each side. The GC's side brackets where they bolt up to the frame are the same as xJs if that helps. I needed to extend each side as the MJ's frame rails are further apart. Used 2.5 heavy square tubing (2.5" ID) to sleeve it together. So you attached to the underside of the MJ frame rails rather than to the sides? About how much did you have to stretch the hitch? Link to comment Share on other sites More sharing options...
cruiser54 Posted April 3, 2016 Author Share Posted April 3, 2016 On 4/2/2016 at 10:47 PM, Eagle said: On 4/1/2016 at 8:23 PM, cruiser54 said: 93 Grand cherokee aftermarket hitch. The GC's rear bumper brackets supply 2 of the 3 nuts for a nut strip, with some cutting involved. One of the 2 holes is off a bit so I had to drill a new hole on each side. The GC's side brackets where they bolt up to the frame are the same as xJs if that helps. I needed to extend each side as the MJ's frame rails are further apart. Used 2.5 heavy square tubing (2.5" ID) to sleeve it together. So you attached to the underside of the MJ frame rails rather than to the sides? About how much did you have to stretch the hitch? Yes, and 6". Link to comment Share on other sites More sharing options...
benjy_26 Posted April 3, 2016 Share Posted April 3, 2016 On 4/2/2016 at 2:03 AM, mikekaz1 said: I just finished this today. $60 for the plates from Brandon, $20 for the 2.5" tube, $20 for the receiver and $20 for powder coat. Who's making side plates? Link to comment Share on other sites More sharing options...
mikekaz1 Posted April 3, 2016 Share Posted April 3, 2016 On 4/3/2016 at 2:16 AM, benjy_26 said: On 4/2/2016 at 2:03 AM, mikekaz1 said: I just finished this today. $60 for the plates from Brandon, $20 for the 2.5" tube, $20 for the receiver and $20 for powder coat. Who's making side plates? Krustyballer16 Link to comment Share on other sites More sharing options...
johnj92131 Posted April 3, 2016 Share Posted April 3, 2016 On 4/3/2016 at 2:16 AM, benjy_26 said: On 4/2/2016 at 2:03 AM, mikekaz1 said: I just finished this today. $60 for the plates from Brandon, $20 for the 2.5" tube, $20 for the receiver and $20 for powder coat. Who's making side plates? http://comancheclub.com/topic/47686-hitch-plates/ Great quality. Great deal! Link to comment Share on other sites More sharing options...
cruiser54 Posted April 3, 2016 Author Share Posted April 3, 2016 On 4/3/2016 at 3:29 AM, johnj92131 said: On 4/3/2016 at 2:16 AM, benjy_26 said: On 4/2/2016 at 2:03 AM, mikekaz1 said: I just finished this today. $60 for the plates from Brandon, $20 for the 2.5" tube, $20 for the receiver and $20 for powder coat. Who's making side plates? http://comancheclub.com/topic/47686-hitch-plates/ Great quality. Great deal! Is there a website or contact info I could link to my website? Link to comment Share on other sites More sharing options...
mikekaz1 Posted April 3, 2016 Share Posted April 3, 2016 You'd have to PM Brandon for an email or something. And if he's OK with that. Link to comment Share on other sites More sharing options...
krustyballer16 Posted April 4, 2016 Share Posted April 4, 2016 On 4/3/2016 at 1:28 PM, cruiser54 said: On 4/3/2016 at 3:29 AM, johnj92131 said: On 4/3/2016 at 2:16 AM, benjy_26 said: On 4/2/2016 at 2:03 AM, mikekaz1 said: I just finished this today. $60 for the plates from Brandon, $20 for the 2.5" tube, $20 for the receiver and $20 for powder coat. Who's making side plates? http://comancheclub.com/topic/47686-hitch-plates/ Great quality. Great deal! Is there a website or contact info I could link to my website? this is the only place i have them posted. I'm not sure the best way for you to post them other than to tell people to get on here and PM me. i don't check email that often. Text or a call would work also 812-236 6109 (everybody try to keep this as adult as you can and no horseplay with my number.) On 4/3/2016 at 2:16 AM, benjy_26 said: On 4/2/2016 at 2:03 AM, mikekaz1 said: I just finished this today. $60 for the plates from Brandon, $20 for the 2.5" tube, $20 for the receiver and $20 for powder coat. Who's making side plates? i am. just PM me or you can click the above link for information. Link to comment Share on other sites More sharing options...
benjy_26 Posted April 4, 2016 Share Posted April 4, 2016 Grassy-@$$! I'll most likely be contacting you soon. Link to comment Share on other sites More sharing options...
