rear drive shaft options
not that anyone has found yet.  between the exactness needed and the insanely huge variety of driveshafts out there, it's the ol' needle in a haystack (made even worse by junkyards that frequently bend the rear shaft when they pick up the truck with a forklift).
When I swapped in my AW4 my rear shaft was 1.75" too long.  I had the local drive line shop shorten it, check it for balance and put in my new u-joints for $45...they even painted it.  Took a day. YMMV.  I thought that was pretty quick and easy
  On 3/4/2016 at 4:18 PM, hornbrod said:
  On 3/4/2016 at 3:57 AM, xjrev10 said:
I did a HNT also when I did my conversion. Had a custom shaft built with heavier wall tubing to the tune of $300ish.
HNT?    :hmm:
Hack and Tap, Slip Yoke Eliminator (SYE)
