ORCA Posted July 18, 2007 Share Posted July 18, 2007 whats that in ur bed? Link to comment Share on other sites More sharing options...
LEAD_NOT_FOLLOW Posted July 18, 2007 Author Share Posted July 18, 2007 whats that in ur bed? PO had installed a tow hook. I would or removed it, but it's welded to an underframe support and it looks like more trouble to remove it than to just leave it... Link to comment Share on other sites More sharing options...
jake Posted July 20, 2007 Share Posted July 20, 2007 Hmmmm taking off the doors? Will you be selling them? jake Link to comment Share on other sites More sharing options...
LEAD_NOT_FOLLOW Posted July 20, 2007 Author Share Posted July 20, 2007 Hmmmm taking off the doors? Will you be selling them? jake Jake, Replied to your PM in regards to the other stuff... I'd sell them if your interested... Link to comment Share on other sites More sharing options...
zjrog Posted July 21, 2007 Share Posted July 21, 2007 Where did you get the SOA spring perch kit? I've seen it somewhere, but can't find it for the life of me. Link to comment Share on other sites More sharing options...
Rokhound Posted July 21, 2007 Share Posted July 21, 2007 Where did you get the SOA spring perch kit? I've seen it somewhere, but can't find it for the life of me. i thought Rock Road had it or something like that http://www.rocky-road.com/index2.html Link to comment Share on other sites More sharing options...
zjrog Posted July 21, 2007 Share Posted July 21, 2007 THATS IT!!! Thanks!!! :cheers: :cheers: Link to comment Share on other sites More sharing options...
LEAD_NOT_FOLLOW Posted July 25, 2007 Author Share Posted July 25, 2007 Where did you get the SOA spring perch kit? I've seen it somewhere, but can't find it for the life of me. I actually got them from a local vendor who sponsor's my local club. I think they are a very similar concept to Rocky Road's. Link to comment Share on other sites More sharing options...
LEAD_NOT_FOLLOW Posted July 25, 2007 Author Share Posted July 25, 2007 Not a lot of updates over the past week as I really haven't had time to work on it. I did get a chance today to pick up some parts for it however. I purchased a set of 6.5" coils for the front, and a set of upper and lower control arms to work with the 6.5" coils. This should help match the rear lift height with the spring over. And I also picked up a D44 rear for an XJ. Not sure if I'll put it in the MJ or one of the XJ's yet... :D Pics: Link to comment Share on other sites More sharing options...
LEAD_NOT_FOLLOW Posted July 29, 2007 Author Share Posted July 29, 2007 Not a lot of updates over the weekend. Was busy spending time with the family. I did however get the front re-tore apart to get the new springs/control arms in. Everything is pretty much out. I should be able to hopefully get the front suspension tied up over the next 2 days. Will report back with pics soon. Link to comment Share on other sites More sharing options...
bhorocks Posted July 29, 2007 Share Posted July 29, 2007 by chance could you snap a pic of how you did the rear shock mounts? Link to comment Share on other sites More sharing options...
LEAD_NOT_FOLLOW Posted July 29, 2007 Author Share Posted July 29, 2007 by chance could you snap a pic of how you did the rear shock mounts? They are factory. I used the existing plates at the bottom of the pre-fabbed brackets. I made no changes what so ever to them. Link to comment Share on other sites More sharing options...
bhorocks Posted July 30, 2007 Share Posted July 30, 2007 like this? Link to comment Share on other sites More sharing options...
LEAD_NOT_FOLLOW Posted July 30, 2007 Author Share Posted July 30, 2007 Here is a pic of what it looks like. I wanted to keep them as low as I could so I can put in a longer travel shock. Link to comment Share on other sites More sharing options...
bhorocks Posted July 30, 2007 Share Posted July 30, 2007 ahh i see different u-bolts. i found that as high as they are then my shocks are way to long. I would prefer t odo the way you have it. just need new u-bolts. Link to comment Share on other sites More sharing options...
LEAD_NOT_FOLLOW Posted July 30, 2007 Author Share Posted July 30, 2007 ahh i see different u-bolts. i found that as high as they are then my shocks are way to long. I would prefer t odo the way you have it. just need new u-bolts. Actually just used regular bolts. Used a grade 8 that's 7" long and they worked well. Their is a peice that is on their from the factory as well (the bolts go threw it, it has a raised bent center); I used that under the "shock plate" on the bottom side for a bit of extra added support. Link to comment Share on other sites More sharing options...
bhorocks Posted July 30, 2007 Share Posted July 30, 2007 awesome. looks like i won't have to weld on new shock mounts. go pick up some bolts tommorow. Link to comment Share on other sites More sharing options...
LEAD_NOT_FOLLOW Posted July 30, 2007 Author Share Posted July 30, 2007 Was able to work on it for a few hours today. New bumper showed up from Motion Offroad, so I was excited to get that installed today. Install was straight forward and fitment was perfect. Put a set of foglights on, havn't wired them yet. I also got the 6.5" springs, bumpstops, and upper control arms in. The lower control arms are giving me a hard time coming out. So I guess tomorrow I'll try to just cut them out. Here are a few pics from today of the bumper: Link to comment Share on other sites More sharing options...
bhorocks Posted July 30, 2007 Share Posted July 30, 2007 lookin good. nice bumper. Link to comment Share on other sites More sharing options...
LEAD_NOT_FOLLOW Posted July 31, 2007 Author Share Posted July 31, 2007 Well got quite a bit of work done today. I first started off the day with cutting the lower control arm bolts on the body side. Talk about NOT FUN! I didn't count how many blades I went threw, but it has to be upwards of at least 10. Once I got those out, the rest of the install went pretty easy. Got the upper and lower control arms in and all bolted up. Got the trac bar installed as well. Front suspension is finally done. Pretty happy with the angles of everything at this height. Than got the 35's installed. I'll let the pics explain the rest. Drove it around the block and it rode well, no weird vibes or anything. I do need to get some new rear shocks in it yet and will trim up the bottom of the lower front flare. I'll also get that ugly red painted black on the frame rail. It was covered with dirt and I need to scrub it done before I do anything to it. More work to come... Link to comment Share on other sites More sharing options...
JeepcoMJ Posted July 31, 2007 Share Posted July 31, 2007 half doors man, half doors :D it's lookin good so far, but I think a nice set of them would really set it off. thunk about puttin TJ flares on the front too? Link to comment Share on other sites More sharing options...
LEAD_NOT_FOLLOW Posted July 31, 2007 Author Share Posted July 31, 2007 half doors man, half doors :D it's lookin good so far, but I think a nice set of them would really set it off. thunk about puttin TJ flares on the front too? I'll probably build a set of tube doors. If I could find a good drivers side door for cheap I may do half doors but they are a ton of work. I've only got what, a week left to get her done in time for the Badlands, it will be doorless as I don't have enough time to do anything else... :brows: I thought about TJ flares on the front. I don't have another set yet, and once again time is a factor at the moment. I'm just going to trim the fenders a bit and probably move the stock flares up a few inches for now. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted July 31, 2007 Share Posted July 31, 2007 half doors man, half doors :D it's lookin good so far, but I think a nice set of them would really set it off. thunk about puttin TJ flares on the front too? I'll probably build a set of tube doors. If I could find a good drivers side door for cheap I may do half doors but they are a ton of work. I've only got what, a week left to get her done in time for the Badlands, it will be doorless as I don't have enough time to do anything else... :brows: I thought about TJ flares on the front. I don't have another set yet, and once again time is a factor at the moment. I'm just going to trim the fenders a bit and probably move the stock flares up a few inches for now. I have a spare set of rear TJ flares here. put rears on the front to match your rears... and I can bring them to the badlands. say, $20 for both? one has a crack in the lower portion where you would cut it to fit body lines anyways... Link to comment Share on other sites More sharing options...
LEAD_NOT_FOLLOW Posted July 31, 2007 Author Share Posted July 31, 2007 half doors man, half doors :D it's lookin good so far, but I think a nice set of them would really set it off. thunk about puttin TJ flares on the front too? I'll probably build a set of tube doors. If I could find a good drivers side door for cheap I may do half doors but they are a ton of work. I've only got what, a week left to get her done in time for the Badlands, it will be doorless as I don't have enough time to do anything else... :brows: I thought about TJ flares on the front. I don't have another set yet, and once again time is a factor at the moment. I'm just going to trim the fenders a bit and probably move the stock flares up a few inches for now. I have a spare set of rear TJ flares here. put rears on the front to match your rears... and I can bring them to the badlands. say, $20 for both? one has a crack in the lower portion where you would cut it to fit body lines anyways... If I was going to do it I was planning on using rears on the front, as I just don't like the looks of the front TJ flares on the XJ/MJ's. I'll let you know on yours. I havn't decided what I want to do yet. I'll PM you before the Badlands and let ya know. Link to comment Share on other sites More sharing options...
offroader461 Posted July 31, 2007 Share Posted July 31, 2007 u have short arms up front?? looks great...keep up the great work Link to comment Share on other sites More sharing options...
