mikekaz1 Posted December 15, 2015 Posted December 15, 2015 curious if any one knows any info on these mirrors, original manufacturer? part number? any trim correlation?
shelbyluvv Posted December 15, 2015 Posted December 15, 2015 I don't think those are factory. Pull the door panel and see if the braces are in the door. Those look like Ranger mirrors with a bolt on extender slide.
ahmincha Posted December 15, 2015 Posted December 15, 2015 Yepp f series ranger Ford mirrors. You can buy the mirrors and the cruush nuts through napa
64 Cheyenne Posted December 16, 2015 Posted December 16, 2015 Stock MJ mirrors like that have a factory strongback in the doors. (structural support)
mikekaz1 Posted December 16, 2015 Author Posted December 16, 2015 the mirror heads are replacement, with the extend a mirror attachment, I know I put those on. the bracket is mj original, the bracket info is really what I'm looking for, as they seem to be MJ specific as of size and contruction. wondering if anyone knew any info on them,
87MJTIM Posted December 16, 2015 Posted December 16, 2015 Those mirror are definitely after market. They are mounted too far forward on the door. The driver has to look through the vent glass to see the mirror. Here's mine. Factory installed
mikekaz1 Posted December 17, 2015 Author Posted December 17, 2015 the brackets are original, they were moved from my long bed to my short bed and relocated inline with the standard corner mirrors as I felt you could see out of them better, especially on the drivers side and to accommodate my 1997 door swap with full window (passenger side not finished) I will say, I'm curious now tho because your mounting flanges are different from mine... yours are flat to the body, where mine mount on half circle plastic isolators with adjustment groves
mikekaz1 Posted December 17, 2015 Author Posted December 17, 2015 I did find this ebay post http://www.ebay.com/itm/1974-Ford-Courier-Truck-Exterior-Mirror-Bracket-Rat-Rod-Hot-Rod-Part-/131666781334?hash=item1ea7f3a496:m:mgJeSugWcQo6vHsjNmZHsPQ&vxp=mtr which look identical to yours
mikekaz1 Posted December 17, 2015 Author Posted December 17, 2015 this ones different from both mine and yours
87MJTIM Posted December 17, 2015 Posted December 17, 2015 AMC = Any Makers Components. Mine is '87. Jeep/AMC/Chry could have changed suppliers over the years.
mikekaz1 Posted December 17, 2015 Author Posted December 17, 2015 Those mirror are definitely after market. They are mounted too far forward on the door. The driver has to look through the vent glass to see the mirror. Here's mine. Factory installed could you do me a favor and post measurements for some of the key features? like screw spacing, bracket width, space between brackets, and door to bracket edge? I want to compare types if possible
mikekaz1 Posted December 17, 2015 Author Posted December 17, 2015 AMC = Any Makers Components. Mine is '87. Jeep/AMC/Chry could have changed suppliers over the years. mine were are from a 1989 if I'm not mistaken
87MJTIM Posted December 17, 2015 Posted December 17, 2015 could you do me a favor and post measurements for some of the key features? like screw spacing, bracket width, space between brackets, and door to bracket edge? I want to compare types if possible I will as soon as my truck is back from the body shop :fs1: :mad: It has been there for 3 months (for the third time) to fix rust they did not correct the first time.
mikekaz1 Posted December 18, 2015 Author Posted December 18, 2015 could you do me a favor and post measurements for some of the key features? like screw spacing, bracket width, space between brackets, and door to bracket edge? I want to compare types if possible I will as soon as my truck is back from the body shop :fs1: :mad: It has been there for 3 months (for the third time) to fix rust they did not correct the first time. thanks! bed side? other then that yours looks awesome!
87MJTIM Posted December 18, 2015 Posted December 18, 2015 Thanks, Those are both pre resto pictures. They were the only ones I could find (quickly) that showed the mirrors. What about the "bed side"?
mikekaz1 Posted December 18, 2015 Author Posted December 18, 2015 Thanks, Those are both pre resto pictures. They were the only ones I could find (quickly) that showed the mirrors. What about the "bed side"? I just meant was it bedside rust why it was getting body work
HOrnbrod Posted December 18, 2015 Posted December 18, 2015 These are the only "low profile" type mirrors issued to the MJs throughout the 86-92 years. There are no others in the factory parts manuals. It is possible however that some dealerships had differently styled options available.
mikekaz1 Posted December 18, 2015 Author Posted December 18, 2015 ah, that's some of the paperwork I wanted to see! that's definitely identical to 87mjtim's too. my brackets seem to be spot on, just the mounting flange slightly different. ill be interested to see what those measurements are compared to mine, I will post mine later tonight
mikekaz1 Posted December 19, 2015 Author Posted December 19, 2015 so my lower bolt holes are 2" apart, top are 4" apart, bracket mounting is roughly 7" between both flanges and door to outer edge is roughly 9"
87MJTIM Posted December 19, 2015 Posted December 19, 2015 Thanks, Those are both pre resto pictures. They were the only ones I could find (quickly) that showed the mirrors. What about the "bed side"? I just meant was it bedside rust why it was getting body work PM sent to Mike. I should get the truck back next week. Fingers crossed. I will get the measurements when it is back in my possession.
Eagle Posted December 19, 2015 Posted December 19, 2015 so my lower bolt holes are 2" apart, top are 4" apart, bracket mounting is roughly 7" between both flanges and door to outer edge is roughly 9" I agree that yours are not factory mirrors or brackets. Does your truck have the vertical reinforcing member inside the doors? (Part #5 in Hornbrod's diagram.)
mikekaz1 Posted December 20, 2015 Author Posted December 20, 2015 so my lower bolt holes are 2" apart, top are 4" apart, bracket mounting is roughly 7" between both flanges and door to outer edge is roughly 9" I agree that yours are not factory mirrors or brackets. Does your truck have the vertical reinforcing member inside the doors? (Part #5 in Hornbrod's diagram.) this truck does not, but the truck they came off of did.
mikekaz1 Posted December 21, 2015 Author Posted December 21, 2015 in any event, even if my brackets are not direct factory, but rather a factory aftermarket or something, they are far smaller (dimensionally) then any of the fords or any other ones I've seen, there about 2 or 3 inches shorter then replacement ford ones, so still not sure how to trace these down to a manufacturer.
shelbyluvv Posted December 21, 2015 Posted December 21, 2015 Small body Ranger pick up has the same size mirrors. Look at my Black Betty build and you can see they are real close. CIPA also sells that style mirror along with JC Whitney and numerous others. Hell, Walmart has them.
