onlyinajeep726 Posted October 29, 2015 Posted October 29, 2015 Alright guys, I'm going from a 2WD Peugeot (internal slave) to a 4WD AX-15 (external slave) in my recently acquired '88 SporTruck. I've disconnected the lines at the slave end and clamped the hose for the time being. My question is, since I'm going to an external slave, can I just mate the hydraulic line from the Peugeot master to an AX slave? The master cylinder looks to be fairly new (PO said it was, anyway). Just trying to save money if I can because the whole hydraulic system, prefilled, is $100+ on RockAuto. Just the slave is ~$35.
Jackrabbit41 Posted October 29, 2015 Posted October 29, 2015 Just get a pre bled master and slave complete assembly out of the year that that tranny came out of. Thats what i did and had no problems what so ever
Jackrabbit41 Posted October 29, 2015 Posted October 29, 2015 Also, mine from napa was about 97$ or so but i did have a small tax discount form work
87MJTIM Posted October 29, 2015 Posted October 29, 2015 You'll need to make sure the internal bore of the master matches the internal bore of the slave. If the master bore is bigger than the slave bore, you will blow out the slave. The the master bore is smaller than the slave, you will not get enough movement to fully disengage the clutch. You can purchase a pre-bled master/slave kit from Rockauto (or most auto parts stores). Be sure to ask for the kit for a 93+ XJ. Edit: Do not get the 98+ kits
1987Comanche Posted October 29, 2015 Posted October 29, 2015 Does the BA use the same clutch kit as an internal slave AX-15? The internal and external slave AX-15s use the same Lucas master. When Georgia was 2WD and had the internal slave AX-15 I lost the master and bought a new one. When I converted her to external slave 4WD I used that master in conjunction with the slave and plastic hydraulic line that came out of the donor. P/N matched and I have about 10K miles on the conversion. The box showing the P/N is on my build thread if you need it. Good to see you got your external slave AX-15 :thumbsup:
onlyinajeep726 Posted October 30, 2015 Author Posted October 30, 2015 Does the BA use the same clutch kit as an internal slave AX-15? The internal and external slave AX-15s use the same Lucas master. When Georgia was 2WD and had the internal slave AX-15 I lost the master and bought a new one. When I converted her to external slave 4WD I used that master in conjunction with the slave and plastic hydraulic line that came out of the donor. P/N matched and I have about 10K miles on the conversion. The box showing the P/N is on my build thread if you need it. Good to see you got your external slave AX-15 :thumbsup: Not sure TBH. And THANK YOU a ton!
