I have a newer 4.0 with the 0630 head that is not drilled for the coolant temp sender in the back of the head and need to relocate the sender to the thermostat housing . From what I've found out so far is the sender is 1/8 x27 thread and the hole in the thermostat housing is 3/8 pipe thread .The 1/8
X27 has proven to be the difficult thread to find .
I need an adapter to mate the two together unless it would not read correctly because not enough of the sensor is in the coolant . I seen where Cruiser said to relocate to the thermostat but I'm open to other ideas and would rather not try my luck at drilling / tapping the head . Thanks in advance .
Btw it's an 88 renix 4.0 that I'm working on .
That's pipe thread, also known as NPT.
You need a bushing from 3/8 NPT to 1/8 NPT. Common as belly buttons.
Thanks Cruiser none of the local parts stores have the bushing and there are no Napa's close so it looks like I'll have to order one . Thanks again
As Cruiser wrote, go to a plumbing supply house. Pipe threads are NOT machine screw threads. Pipe threads are slightly tapered, so that as the male piece is threaded into the female hole the fit get's tighter. Whatever you do, don't try to use machine screw parts (or taps or dies) where you need pipe threads.
There are quite a few reports on the stroker forums of guys using the 0630 head w/o the temp sensor hole and using the bushed down thermostat housing hole instead. It almost never works because the sensor element is not immersed enough to provide accurate temp readings. I'd drill and tap a 1/8 NPT hole on the head boss if it were me.
Not to hijack a thread, but your rreply brings up a question Don.  I have an 88 with the gauge temp sensor in the rear of the head and i have moved the computer temp sensor to the thermostat housing.  Is it possible that my poor gas mileage is partially due to a low reading from the thermo sensor?
The sensor this thread focuses on is only for the temp gauge, IIRC
In standard configuration, the Renix system ECU temp signals come from the temp sensor on the left lower side of the block under the exhaust manifold. If you have moved that to the stat housing, theoretically it will be sensing cooler coolant temperatures and could possibly affect mileage as it will run richer.
For the HO's, the ECU temp signals come from the sensor in the stat housing.
Well here's what I've come up with today and I mean ALL day of running around .
I found this bushing and the sensor won't even go in because the bottom of the sensor hits the tapered threads ...
Then I found this one where it threads in but doesn't look like it will give an accurate reading ..
I think that will work since it's only for the coolant temp gauge, si? If it's not indicating correctly you can always plug it with a 1/8" NPT plug. BTW, 1/8" x 27 as in your first post thread is 1/8 NPT.
It will be a week or two until I have the engine running to make sure it won't leak .
Thanks for all the replies/ help .
That would be fine as would be shortening the bushing so the sender projected out past the end of it.
Either way. Pipe threads naturally seal as they are tapered.
I wish I had my son in law's Jeep here.......
