docivy
Everything posted by docivy
2.8 rebuild and swap options.
docivy replied to jwidmer's topic in MJ Tech: Modification and Repairs
That's why I had said a whole donor truck. I've got a friend with one that was rear ended so I can get literally everything for $500. As far as motor mounts and the transfer case mount I'm able to fab those and I'm a while by trade so I can do all that at home. My biggest reason to consider it is my whole drivetrain in my truck is rough. Not to mention I have an 86 with a non 4.0 firewall. Over heating is the reason I don't go Sbc -
The price of doing all this is pushing me to just buy a whole 4x4 s10 4.3 and swap to a 90 degree v6. It's super easy to slap a carb on , not to mention I would like a 700r over a Ax5 -
Readying for rust repair (rockers and floors)
docivy replied to A-man930's topic in MJ Tech: Modification and Repairs
You could cut the rockers out and slap in some 4x6 tube -
Found the problem........it's a rotted fuse panel
Replaced both the flashers today. Driving around when the hazards just started working but they just stay lit if I hit the brakes
I literally just did this to mine. That looks factory to me. I went back with 18 gauge sheet and made my own patches.good luck! A set of wire brushes for a grinder would be a wise investment -
Hey guys I've got an 86 that's signals just stopped working on. No arrows on the dash or anything. The fuse is good and the flashers are now new. Oh and the hazard lights don't work either. Is this a bad switch?
Metric Ton Leaf question thread
docivy replied to jpnjim's topic in MJ Tech: Modification and Repairs
I've got a long bed with factory package and I can say they ride pretty great but I've never loaded it down -
Ride height / track bar question
docivy replied to Paul Bruchal's topic in MJ Tech: Modification and Repairs
If you want to go 4.5 then an adjustable track bar is in your future regardless. So I would just go ahead and get one. -
One wheel rubbing on new fenders
docivy replied to buckwheat's topic in MJ Tech: Modification and Repairs
Within an 1/8" should be fine. Why not just trim and run tj rear flares up front. Plenty of room -
jeep mj with 33s and stock gearing yes or no?
docivy replied to eyepod's topic in MJ Tech: Modification and Repairs
Heck I ran 3.73 and 35s on tj with a 4 cylinder for over a year.......anything is doable haha -
Need a pipe adapter
docivy replied to Strokermjcomanche's topic in MJ Tech: Modification and Repairs
http://m.summitracing.com/parts/mio-mmwhs-38-bk This seems easier and honestly allot less headache than taping the head -
Need a pipe adapter
Yep I work part time at the home depot and we most certainly have them -
8.8 fluid and welding housing to tubes
docivy replied to Jackrabbit41's topic in MJ Tech: Modification and Repairs
Tubes are .25" housing is around the same. Don't make big wide welds and tap on the cast with a hammer as it cools -
Ive got an 8.8 in my tj that I cold welded with some nickel rods and I have beat that thing. No problems yet, it is trussed though -
A vacuum leak will with no doubt cause running issues
Any difference in the idle problem with it attached
You can use a tj or xj Dana 30 up front with no problems. The only thing to think about is high pinion vs low pinion
Dang that's no good. This winter I'm doing a motor swap on mi e then putting a 100% new ac system in. Not looking forward to these problems
Ive got a super winch lp8500 and it does great
Hello and I could use some advice!
docivy replied to Soulesonic's topic in MJ Tech: Modification and Repairs
I have the exact same truck! Is yours v6? -
I'm in the process of getting a 2.8 mj on the road. Good to see someone else running it
Need help, with lift plan
docivy replied to 1st time jeeper's topic in MJ Tech: Modification and Repairs
Stay away from cheap lead springs! Theyre going to sag or break or both -
Ive seen allot of good reviews. I did herculiner in the cab of my s10 and loved it
