ggcnash Posted July 23, 2015 Share Posted July 23, 2015 Hi guys gonna make a run to the JY tomorrow, buddy told me there is an 88 MJ 2.5 Auto. That tells me 4.56's right? If so we're the stock axles with 4.56's usually d35's, d44's or just a toss up depending on options? Link to comment Share on other sites More sharing options...
ggcnash Posted July 23, 2015 Author Share Posted July 23, 2015 Obviously front is a d30 just talking rear thanks! Link to comment Share on other sites More sharing options...
MJam86 Posted July 23, 2015 Share Posted July 23, 2015 Front D30 would be a CAD axle, rear most likely a D35 some D44 Link to comment Share on other sites More sharing options...
ggcnash Posted July 23, 2015 Author Share Posted July 23, 2015 Front D30 would be a CAD axle, rear most likely a D35 some D44Yea don't want the front just rear. Just trying to figure out if all stock XJs, MJs with 4.56 geared rear diffs were d44's for some reason or other? Never seen 2.5 auto MJ, have come across a couple XJs though and both had 4.56 d44's? Just wondering, guess I will find out tomorrow Link to comment Share on other sites More sharing options...
Blue XJ Posted July 24, 2015 Share Posted July 24, 2015 I grabbed a set of axles from a 2.5 auto XJ years ago. It was a D30/D35 combo with 4.56's. Link to comment Share on other sites More sharing options...
AeroNautical Posted July 24, 2015 Share Posted July 24, 2015 I thought the ratios worked like this: Â 2.5 Auto: 4.10 Manual: 3.55 Â 4.0 Auto: 3.55 Manual: 3.07 Â Is that not how it worked? Link to comment Share on other sites More sharing options...
88whitemanche Posted July 24, 2015 Share Posted July 24, 2015 The 2.5.... Ax4- 3.55 Ax5-4.10 Think aw4- 4.56s Link to comment Share on other sites More sharing options...
Exxon Valdez Jeep Posted July 24, 2015 Share Posted July 24, 2015 if its a 4 cyl AW4, it should be 4.56s, otherwise 4.10s. grab me the bell housing if its an AW4 4 cyl, Ill pay for it Link to comment Share on other sites More sharing options...
ggcnash Posted July 24, 2015 Author Share Posted July 24, 2015 I grabbed a set of axles from a 2.5 auto XJ years ago. It was a D30/D35 combo with 4.56's.Exactly what I was wondering, not what I wanted to hear obviously, oh well we will see tomorrow. Thanksif its a 4 cyl AW4, it should be 4.56s, otherwise 4.10s. grab me the bell housing if its an AW4 4 cyl, Ill pay for itMaybe someone can confirm this, but from my research all MJs from 87 to 92 with 2.5 auto had the aw4 with 4.56. If it's there I will try to help you out. Link to comment Share on other sites More sharing options...
shelbyluvv Posted July 24, 2015 Share Posted July 24, 2015 I got my 30/35 4:56 geared axles put of a 84 2.5 auto XJ. Not all auto 4 bangers had 4:56s though Link to comment Share on other sites More sharing options...
ggcnash Posted July 24, 2015 Author Share Posted July 24, 2015 I got my 30/35 4:56 geared axles put of a 84 2.5 auto XJ. Not all auto 4 bangers had 4:56s thoughYea, I knew prior to 87 on XJs and 86 MJs it is hit or miss with ratio, axles ,and trans but in 87 -89 fsm all that is listed that I can find is 4.56 ratio axles and AW4 behind the 2.5 with auto? Link to comment Share on other sites More sharing options...
ggcnash Posted July 25, 2015 Author Share Posted July 25, 2015 Could not get off work early enough today gonna try again tomorrow evening Link to comment Share on other sites More sharing options...
